flat battery
- Thread starter Alpine
However, you are not alone with this problem. The first step is to stick an ampmeter between the positive cable and battery post with the car off and at rest and see what you are drawing to keep the radio memory, alarm, etc. running. You should see somewhere around a 0.050 to 0.075 amp draw. If you are higher you know you have an extra draw somewhere.
Standard procedure is to start pulling fuses and watch when the draw drops and you know what circuit to go after. Common problems are aftermarket sound systems, the alarm, glove box light staying lit due to faulty switch, and the front door switches staying engaged and powering up.
You could also just have a bad or dirty battery. Though dirty isn't as likely with RHD cars. But look at the battery top and see. What happens is you get a halfway decent conductor built out of dirt and salts and it soft shorts between the positive and negative posts. Soft enough not to make sparks but it will drain the battery in a week or two.
http://www.solar-batterycharger.co.uk/BatterySaver%20Plus.htm
951Torqing
To keep a decent battery in top condition I have done a double whammy & got a "Dis-Car-Nect" (quick battery disconnector) £9.99 incl. delivery from ww.speeding.co.uk and a Carcoon Battery conditioner (£40!) to keep it (intelligently) fully charged.
Hope this is of use, it should help if your battery is ok.
After having the alarm lock me out of the car while washing it with keys in ignition for the radio two times, I tore it out and repaired the hack wiring installation job. If you have the Clifford alarm that would be on the top of my list for battery drain.
ORIGINAL: Doc
Have similar problems with my cars battery going flat after a few weeks of non use. Has anyone tried solar panel battery chargers? I know we dont get much sun in this country but are they good enough to stop the battery going flat?
I had battery problems with my 944 which was regularly left idle for a week or so.
I tried a solar charger which I found helped to ward off the voltage drop, but not enough current generated by it to maintain the battery at full charge. However, it certainly meant the difference between there being enough charge to start the engine - or not if I didn't use it.
Bear in mind solar chargers will still generate a current in daylight, but not as much as it will in direct sunlight.
Big Dave
http://www.porscheclubgbforum.com/tm.asp?m=430627
It is for a 968, but if you can get into the car via the doors then its an easy fix....
Im not too sure if there is a bonnet release cable on the 944,s as there is on a 968.. BUT i suspect there will be...
Neil Haughey
Apparently the 968 CS and some 944's have a cable boot release nearer to the driver, the 968 PET shows this, its something I will likely need on my S2 race car project in the very near future i.e. before access to the rear is made impossible by the cage.
on pre 87?? cars the boot could also be opened with the key (my oval dash 86 would).
Cars with the electronic boot release with a microswitch (87 on? - why did they change?) have a terminal under the bonnet in the scuttle area on the drivers side near the vacuum resovoir (black cylinder) Unscrew the blue plastic cover and attach a jump lead (+ve) and a negative lead to the engine somewhere you will have plenty of power to open the boot. You can then jump start in the usual way at the battery end - never tried doing it from the front as the cables seem a bit thin but it might be possible.
Tony
Gavin944s2
i'll get under the bonnet to the 'blue'cap ..many many thanks ..
pauljmcnulty
i have similar prob that the boot keyhole is frozen and the boot lid stuck down with ice,
Guess I will have to climb through.
Although I didnt kno about the neat idea of using the positive post under the bonnet - do I have that on my Lux?
steve
944 man
All series two cars should have an electronic hatch release. Its in the right hand side of the cabin though (alongside your right calf), not the left, which is where youll find the bonnet release lever. You car uses cables, so the only way to open the hatch if its all frozen up (although Id warm the car up myself, and wait, using nothing more than a hot key) is to pull the cables found behind the boot carpet along the rear panel.
Simon
