Apologies if this has been raised before, but I could not find any similar thread.
I went for a drive today in my 991.2 Targa GTS and had a thoroughly enjoyable time. All gauges in the car were as normal throughout the drive.
On the way home, I stopped for some petrol and on pulling away after filling up, after a very short distance I got the Engine Temperature warning indicator coming up, asking me to pull over immediately to let the engine cool down. The fans were also going ten to the dozen.
I pulled over and waited a little while and checked the water temperature gauge, which was still showing 118. As I was really not very far from home, I decided to gingerly limp home but after a very short time, I received exactly the same warning, this time with the water temperature gauge showing 125.
I stopped again and left it longer this time. On restarting, it was still showing a high water temperature reading, but then suddenly dropped back to its normal level (90).
This happened a couple of times last year but I put it down then to the very hot temperatures we experienced, but today the temp outside was only 9 degrees, so this was clearly not the issue.
Has anyone else experienced this? I suspect it may be the gauge is sticking rather than an actual temperature problem but I am obviously going to have to have it looked at. Any advice therefore welcome.
Thanks,
Keith
Thanks,
Keith
