kcbart
My door mirrors are not working as they should and I have found that the wiring to the driver's door mirror has been replaced at some time - all the wires are black! I've got the wiring diagram and I need to trace which wire is which, and have some questions:-
1. where is the connector to the door wiring? I have searched for an answer with conflicting results - is it/they behind the carpet by the boot switch or up near the bulkhead under the dash. Probably changed with time - mine's an 89 2.7.
2. I tried to find 2 earths at the mirror - one for the heater and one for the motors, but couldn't find any, which would explain why the heater isn't working. Where does the heater earth wire go to?
3. The wiring diagram shows the motor earth going via the adjusting switch - am I right in thinking that this will only be connected to earth when the switch is being operated, which would explain why I didn't find the earth at the mirror.
Many thanks for any help - I am sure there will be more questions to follow,
