dash voltmeter
DavidL
What does this measure - state of charge or rate of charge? I've got another basic voltmeter attached and the figures broadly agree but I feel I'm seeing quite low figures. At idle it drops to 12.2 and running 12.5 to 13. Load doesn't seem to make much difference. Through the summer little was on, no heated seats, lights, heater etc but I don't recall the numbers being higher than last winter when these items were in use. I've not put a meter across the battery in these conditions but it sits for a couple of weeks and still starts fine so I can't imagine it's not charging. Battery and starter are new.
eta battery load tester says charging is good so nothing to worry about?
It measures battery voltage and can be calibrated via a little turning resistor at the back of the gauge. I calibrated mine with the engine off but ignition on and it's now spot on with engine off and not too far off when engine running. You want to be seeing about 14 volts running with not much switched on (I get about 14.2v on cold idle at start up), at least 13.5v anyway (either on your gauge if it's calibrated properly or straight off the battery on your voltmeter). If you're only getting 12.2v at idle when running I'd suggest your alternator (or battery ) isn't performing very well (or the gauge is wrong). Get a meter on your battery when it's running and see what you get and calibrate your gauge like I said and see how you get on.
Thanks Stuart, I didn't know it was adjustable. The battery tester suggested charging was ok, I recall seeing about 13.6v on idle. I'll check off and running and see what it ays.
