Chips Away Demo?
- Thread starter Guest
Here are before and after pics.
One or two of the chips on my bonnet are still visible, but he reckons there is about 8 coats of paint on it and would take an age to keep on putting on the layers. My main concern was the door edges which are sorted - plus he left the paint so I can try putting more layers on the bonnet with a fine brush.
I got a guy in Guildford Surrey
Some people may call you a very lucky boy..... Some people may not.....
Any chance you can post his number. I desparately need someone to sort out my front end. He' s not getting anywhere near my rear though.....
Elliot Davies
May have to get the local Reading one to sort out a few on mine, the door edges on mine are worn in that you can see the base coat through the top coat.
What did he do to prep the surface ?
Did he use a mini spray gun ??
Elliot Davies
Elliot Davies
to see how he prepped the areas to be sprayed
Hopefully he put some rust killer on the edges pre painting ?? I suppose either way it is still far better than it was previous
