I had my GPF replaced 12 months ago now and I went back to the OPC to have it checked aprox. 4 weeks ago, they reported it was 39% full and at stage 2, they informed me at stage 3 it needs a re-gen and the filter light will come on to tell me, I don't think so!!!! didn't come on last time, I'm convinced it's not even there! Then stage 4 it needs replacing at a cost of £7500.
They said it's my style of driving that's the problem and if my journey is less than 30 mins not to drive it....absolutely ridiculous. I asked them if they could check the AOS as I believe mine has got the earlier version which had a diaphragm that was prone to failure and the latest AOS is a sealed unit, they said they could check it at a cost of £264, when I asked what the check consisted of they said:
"I have checked with workshop control; they have advised there is no set pressure test or procedure in place sadly,
We would carry out a fault memory check and check fuel to air ratios to check for any boost or vacuum leaks.
If there are no faults in the memory, it is likely we will not be able to provide a diagnosis.
If there is an issue with the AOS it will flag up the engine management light on the dash"
And they wanted to charge me £264 for this!!!!!
If the engine management light comes on for an AOS failure it's probably too late!!
I am convinced that Porsche know of these problems....why don't they just sort it out!!
Mark
Mark
