Broken Rear Coil Spring
AnSGTS
I took my 2018 991.2 GTS into my local
OPC for its 8 year service today. They called around lunchtime to say one of my rear coil springs was broken.
They quoted £1,200 to replace both rear coil springs & £350 for a 4 wheel alignment.
The car is still under Porsche Extended Warranty, I queried if the coil was covered but I was told it wasn’t.
Does anyone know of this is definitely true?
I can understand the shock not being covered, but I would have expected the spring to be covered
Thanks!
Your OPC is wrong. Springs are covered under the warranty (or at least they were), dampers are not. I suggest you read your warranty insurance docs. There is some difference depending on when you took out the warranty as the insurer has changed. However, pretty sure springs are still covered. Who is the OPC?
£350 for an alignment is the typical OPC comedy price. Go to an indie. Most alignment machines have Porsche alignment info on them.
Thanks for the reply, I thought as much. It’s South Lakes Porsche. I purchased the car from them 2 years ago. They’re usually excellent, I’ve already had my moneys worth from the warranty, two new headlights and two new turbos (£14k bill)
A broken suspension spring is typically covered under the Porsche Extended Warranty as long as it’s due to a technical defect and not caused by external damage or wear-and-tear from misuse. It includes coverage for defects in suspension and steering system,
What is not covered is damage from accidents or improper modifications, wear-related issues (e.g. corrosion, fatigue from overloading) and shock absorbers may be excluded in some cases.
Regards,
Clive
Thank you to everyone for the help and advice. Annoyingly, I tried but ended up having to cover the repair costs:
“we have come to the conclusion your coil spring issue has been caused due to wear and tear. As the gravel and dirt has got caught up in the shock absorber cup it has worn away the protective coating on your Coil spring. Subsequently the bare metal has been exposed to the environment and has caused the fracture in the coil spring. This is deemed as wear and tear as it has occurred gradually over a long period of time”
How many mile ? I visited OPC Burges Hill this morning with the female owner of the GTS. 2017 but only 15,000 miles.
They are trying to say the brake is caused by corrosion so not covered by the warranty. There are no visible signs of corrosion. Has anyone successfully managed to claim under Porsche warranty ?
My car is an 18 plate, and has covered almost 22K - I’ve done 9k of those miles in 2 years. I all honesty I hadn’t even noticed any issues with the handling so it was quite a surprise. I went back and forth over email, then a phone call. They even discussed the issue with their resident warranty expert and agreed the outer protection had worn, allowing moisture and road salt to ingress.
