Bonnet Release
- Thread starter GPF
Yesterday, showing the beast to a friend, the boot catch was a bit tough but soon opened. The catch travelled further than it should have though once released. Today I go to have a look at it, the catch is moving freely, but sadly the bonnet it not opening. With no Haynes book to check, you are my first port of call!
The cable appears to be attached to the catch, so is it likely that the cable has snapped, or come detached from the bonnet release? Can I release the bonnet any other way to check the cable? Any other advice?
George Elliott
I had this fail a few months back, you need a new plastic moulding which I got off e-bay, (ask on here perhaps) its about a tenner, not much more new I think. While you are working with the broken lever assembly, you need to hold the cable outer, dont just pull the handle which is still attached or you will damage the cable where it passes into the bulkhead behind the dash. good luck George 944tYou can often pull the cable directly to release it.
