Anybody used Swepco
- Thread starter cococola
Wigeon Incognito
Bert has 201 80/90 or the slightly more expensive 80/140. I don't mind the extra cost but wouldn't want to pay it if the product isn't thought to work as well.
cococola
ORIGINAL: Wigeon Incognito
A quick question to add to this, which is the Swepco to go for?
Peter Empson
xenon
ORIGINAL: Robbo149
And how easy was it to do on the 944?
Cheers,
Robbo
Lemon Squeezy. Remove the fill before the drain plug to make sure it comes out OK (if you remove the drain and empty the transaxle only to find the fill rounds off, well you get the idea...) Warm the plastic bottles of oil in a bucket of hot water for a while to make it more runny (TX oil is very viscous) and you just need a length of clean hose to feed up and over the n/s/r wheel. You hold the end of the hose in the fill whilst an assistant squeezes the oil in.
Paul Fraser
How much do you need?
What type did you buy?
Cost?
Where from?
Ta.
Wigeon Incognito
Are 2 quarts (circa 0.1L shy) enough? I'd guess so but don't want to make a stupid mistake!
Paul Fraser
