Elliot
ORIGINAL: scam75
Hi Tom
I have an ABS problem which I believe to be the pump. My light stays off as it should all the time (lights up with ignition then goes out as normal), pump whirrs happily but ABS is completely inoperative. This also happened to Super Marv's 968 and he had the pump replaced which cured the problem.
Therefore a faulty pump does not seem to light up the warning light whereas problems with sensors, wires, ECU's will.
So I would say your pump is fine and always was, the problem will be electrical.
Incidentally I need a working ABS pump if you have a spare!
Hope this helps
Stuart
I have three pumps if you still need one
