Antilock warning light - ABS Pump anyone?
- Thread starter Tom
Tom
I've done a bit more research and have found out the following generic information about ABS self test. It would be great if someone could confirm at what point the pump is tested (if it is tested).
Ignition turned on: Anti-lock light lit (along with all warning lights).
Engine started: Apparently most systems carry out a check of the ABS solenoid valves at this point. They are tested by monitoring the current through each solenoid when energising the valve for a short time. This can detect most problems such as a stuck valve, shorted wiring or open circuit conditions. If tests pass, anti-lock light clears. The solenoid valves are part of the pump assembly on our cars.
Car moving: The pump is actuated to prime the accumulator (also part of the pump assembly) at about 3mph. Mine used to operate when I reversed out of the garage, so this is definitely done at a very low speed. The signals from the wheel sensors are also checked but I'm not sure at what speed this is done.
With my car, the pump no longer groans when I first move off. As soon as I get up to a higher speed (6 mph?), the anti-lock light comes on.
So the big question is - Is the pump not groaning because it is tested at 3mph and fails (if so, why doesn't the anti-lock come on at that speed?) or is it that the wheel sensors are failing so the pump is never actuated? The only other thing I can think of is that the pump is switched on at 3mph and maybe there is a check done at the higher speed to check it has stopped, reached normal pressure etc.
Tom
I decided to do some diagnostics myself, since the garages that I have used have all failed to fix the problem, I've already had a replacement ABS pump fitted (against my instincts and advice from people on this forum) and I didn't want to throw any more money at it. What I've discovered is that one of the connections to the rear left wheel sensor is shorted to ground. For the record, I tested the wiring as follows and it is very easy to get to:
1) Pulled out boot release switch and removed carpet on right hand side of drivers footwell - it is velcroed along the bottom and the end furthest from the door.
2) Disconnected connector from the ABS ECU. There is a spring clip at one end only: Once this is released, you pull that end away as far as possible and then the other end unhooks from its retainer.
Note: When referring to the wiring diagram (944 Turbo, 944 S Model 90 Sheet 13, Page 97) the pins on the connector at the end of the wiring loom are numbered top to bottom, right to left , so Pin 1 of the connector socket is at top right when you bend it round to face you.
3) Made two cables with small spade terminals on one end to fit in the ABS ECU connector socket.
4) Tested resistance between each pair of sensor connectors - (11 & 21, 4 & 6, 8 & 9, 24 & 26). All came it at just under 1k ohm (lowest 955 ohms, highest 986 ohms).
5) Jacked each side of car up, attached oscilloscope to each pair of sensor connectors, spun wheels and checked trace. All produce a sine wave with similar voltage.
6) Tested resistance between each sensor connector and ground. Rear left sensor pin 8 shorted to ground, pin 9 has 952 ohms to ground (about the same as the sensor resistance).
So I'm now pretty certain that the short to chassis is the cause of the problem and fits with the original symptoms which began with the anti-lock warning light coming on occassionally when I reached about 10mph.
If you've read this far, thanks!
Anyone got any idea where the short is likely to be? I'd like to disconnect the sensor cable at the rear trailing arm and see which side (sensor or ECU end) has the short but not sure how to get it apart (don't want to break it).
bertelli_1
I've found two earths not connecting so far, as I understand it the caliper should be directly earthed, but still have got the warning light and checked the sensors on those wheels too, but undoing the "barrels" as Bertelli says, so I think I'm on the right track!
Tom
bertelli_1
Tom
It's FIXED !!!!!
No more nasty warning lights.
So my advice to anyone else with "Anti-lock warning light comes on at 6mph" problem is to not only check the sensor connections for resistance and signal but also for a short to the chassis.
bertelli_1
On my car the ABS and main warning lights illuminated once the car was moving.
The ABS light was off after the car was started but before it moved away.
My Independent dealer checked everything and the problem was the pump.
I source a replacement pump and the dealer cleaned, rebuilt and fitted it.
Where the pump is fitted seems to collect a load of crud which does not help.
Mike
White 2.7 automatic
924nutter
Erm... Correct me if I am wrong but isn't the sensor buried deep in the pad recess and open circuit until the pad wears sufficiently for the disc to short the two contacts together?ORIGINAL: Riverside
ORIGINAL: D7MPJ
My ABS light is on and the large brake warning light that i asssume is ref the handbrake? (red) in middle of dash, i have only just bought the car and the discs and pads were knackered, i have replaced now but was hoping the light would go out, any suggestions on my likely cause?
I'd guess it's the pad wear warning light maybe?
The brake pad wear sensors work by having a closed loop of wire which makes a circuit. Once the pads wear down to a certain point the sensor wire wears through & breaks the circuit. Just replace the sensors, or make the circuit another way if you are happy to live without pad wear sensors.
ORIGINAL: 924nutter
ORIGINAL: D7MPJ
That's one that can be tested yourself if you doubt it. Disconnect a pad wear sensor (ie break the circuit) & if the dash light comes on then you know an unworn sensor completes the circuit. If the light stays off with the sensor disconnected you know it doesn't. The sensor is as I described, it's just a loop of wire in a plastic block.
Neil Haughey
One or two ppl posted similar experiences over in the 964 section.
Thanks Tom and all for posting a useful thread.
