The aircon on my C4S is refusing to work. The fan does work, but just blows air. Using the PCM display, the A/C ‘button’ does light up for only for a second or two before disappearing and the ‘A/C off’ message appears on the dash. Any suggestions for an easy fix please? Or is it inevitably a trip to the dealer? Many thanks
Aircon malfunction 992.1 C4S (2019)
- Thread starter laurenceshore
Thanks Marc
A decent diagnostic device will tell you the refrigerant pressure that the car is seeing, but A/C switching off can also be a symptom of a sensor reading "odd" values - so if there are no codes then get live readings from the a/c related sensors and see if everything looks "normal" - I have seen one car where the interior temp sensor was swinging between -50 deg c and +45 deg c every few seconds and another where the refrigerant pressure sensor was happily reporting 53bar - when the operating range is somewhere between 11 and 17 ish .....
Thanks Malarcy. I’m going to borrow a device from a neighbour today and find out some more hopefully. Finding the OBD port wasn’t easy but I got there eventually! Google told me to look to the left side of the driver’s footwell, but it’s actually to the right, above the accelerator.
Porsche often "mirror" stuff like this lhd vs rhd - chances are google (or more likely Gemini) decided to give you "guess" dressed as "fact" - and reported a US post giving the location.Thanks Malarcy. I’m going to borrow a device from a neighbour today and find out some more hopefully. Finding the OBD port wasn’t easy but I got there eventually! Google told me to look to the left side of the driver’s footwell, but it’s actually to the right, above the accelerator.
Thanks again Malarcy. Update: so my neighbour’s ‘pro’ OBD scanner is reporting no faults at all. The aircon hasn’t miraculously corrected itself; it still switches off after very briefly after lighting up. So this is beginning to look like it may be malfunctioning sensors, as you suggested in your first reply of 18th August.
A faulty sensor wouldn't necessarily generate a code - that would require the modules recognise an "implausible" signal - you may be able to spot something if the reader you used was able to read live values of sensors - you can often spot things that looks odd ( like one sensor saying -50deg C and another saying +20 for example)
Update: So I’ve been unable to make any further progress myself and have reluctantly booked the car into an OPC next week. Not my normal OPC - that provided such poor service a few months ago - but another, in a different ownership group. I’ll post again with the result.
Before committing to an expensive trip to the Porsche dealer Laurence, as Marc has suggested it would be worth confirming that you don’t just have a low refrigerant level which is causing your problem. Outlets such as Halfords will perform the check FOC, including a leakage check.
Jeff
Jeff
Thanks Jeff, much appreciated. There’s no Halfords conveniently local to me, but there is a small independent garage with a decent reputation that I might try. The OBD scan my neighbour ran for me didn’t show any problem with refrigerant pressure, but he said we couldn’t rely on that completely. I’m a beginner with stuff like this, but I’m learning a lot, particularly about OPCs.
A quick online check shows that KwikFit, Protyre and other tyre outlets also offer a free service Laurence, and I’m sure that there are others in your area such as the local garage you mention. With Porsche dealer hourly rates at £250+
definitely it’s worth eliminating the obvious if you can before leaving them to sort it out.
Hope you get the problem resolved.
Jeff
Jeff
Update: With the car due at the OPC tomorrow, I’ve just had a phone call to say that rather than the one-hour charge for diagnosis, they will almost certainly need two hours and wanted my authorisation to spend £560. They didn’t get it, and I cancelled the appointment. So I’m off to the local highly-recommended garage. More updates in due course.
Success. The local garage diagnosed low refrigerant pressure and re-gassed the system. Now working perfectly. Many thanks to all for the wise counsel and support.
