Air con regas x 2 in 6 months
mike.plackett
Hi just wondering if anyone has had the same experience, car was new to me in September and garage hadn’t done regas, so got it done. Noticed over the last couple of weeks a/c didn’t seem to be working and confirmed it today as the weather was warmer. I am guessing this isn’t normal, done 3k miles since September and had a/c on most of the time. Any advice or insight greatly appreciated. Thanks Mike
Generally with aircon, the cars HVAC should be left on Auto so it will run the aircon all year. This keeps the seals lubricated. Once seals dry out you can get leaks. A condenser can fail but that's pretty rare. Your best bet is to take it to someone who can do a pressure test on it. Really before any re-gas a pressure test should have been done. Most places charge £20-30 for a test. If it fails that there is little point having it gassed until you find where its leaking.
Something else to consider is if the fan is working. Can you feel moving air via the vents? If not then its probably just a stuck fan which is pretty common. Come the winter or if my car has been unused for a week, this can happen to mine. All you need to do is remove the top of the pollen filter cover and the filter. Reach down inside and you will feel the fan. Just give it a spin with your fingers. Obviously do this with the ignition off!! After this the fan will work. This top tip came from an ex OPC mechanic. Aparently a stuck fan is very common.
Thanks very much for the reply, very helpful, yes fans working, I have it booked in for a regas on Monday but will ask about the pressure test as well. I have extended the Porsche warranty so if it needs something major it will be covered, hopefully!
Only if you can convince them it hasn’t been damaged by eg a stone. But if it wasn’t leaking before you bought it, it wouldn’t have needed a regas.
thanks for the comments, had the regs done and they added UV dye and took it back in week later for them to check for leaks but couldn’t find any. Noticed this last week as it has been warm that cooling seemed to less than it was straight after regas. Then noticed that air was consistently much cooler on passenger side compared to drivers side. Any ideas on this issue ?
I have it booked in at an independent Porsche specialist in a week so for something else so I will ask them to take a look but we’re off the northern Spain in a couple of months so definitely need it fixed by then.
Any feedback much appreciated
