Aftermarket Exhaust and Porsche Warranty
nick.miller
Just after a bit of info on the official Porsche warranty and aftermarket exhausts.
If a car has an aftermarket exhaust and goes to the OPC for a service, will the centre take note/void the warranty at that point. Or would it only be a risk of the warranty being voided if the exhaust is installed and discovered at the point you need to make a claim.
I’m considering adding an exhaust and interested to know if it would need to be removed and official Porsche parts reinstated before a service.
My thoughts being that I could always put back to stock should I need to make a claim. But to do this at each service might be a little too much effort!
Many thanks
If you look on Auto Trader there is cars for sale from porsche dealers with warrantys with aftermarket exhausts fitted, Think if its just a backbox with leaving cats/opf intact etc must be ok, Everyone likes a bit of noise from a Porsche, Lets face it thats what most people want, “Unless you like Electric cars” 🤮
Depends whether you mean the original new car warranty or the Porsche Approved (ie extended) warranty. Different rules apply to each. OPCs can differ in their interpretation of each (not necessarily correctly) and the rigour with which they apply them.
I agree with Brian (particularly in the difference between the original new car warranty and the extended one). For what it is worth my experience of non standard Porsches (admitedly not with exhaust changes), is that it varies between OPCs, and is only likely to be raised if you try to make a claim and it might be related to the exhaust. However some seem to interpet it literally, while others ignore it. It is a pretty common issue, so it might be worth a chat with the relevant OPC and determine their view.
The wording in the OPC extended/aftermarket warranty is such that any fault traceable to the modified part cannot be claimed for, and obviously the part itself is not covered, but that the warranty is not void. An example would be if you fitted a free-flowing system that caused the car to run lean resulting in detonation, then Porsche will not cover it. If you have a custom exhaust and the car suffers a failed electric window, then they cannot avoid this. Grey areas arise in that should the custom exhaust increase power/torque, in the event of a transmission defect Porsche might try to say that it placed extra strain on the system so they won't cover it.
But these items are assessed on a claim-by-claim basis and Porsche will still service the car etc.
The 'from new' warranty is subject to statute (they cannot erode consumer legal protections) but is roughly the same approach: defects traced to your modification are not covered, the custom part and fitting work is of course not covered, but retailers cannot escape their overall liability.
Generally Porsche will push back on any claims if you change stuff - even PPF, I've heard cases on
squicker's comments are correct - however depending on your opc, you might end up with a fight if you want to claim
Age, wear and tear are factors on warranties, as well as anything that can accelerate the wear - so any changes that touch the cat converters or cause excessive pops and bangs for the purpose of creating noise are in the "go straight to void" on any engine related claims
I went Akrapovic slip on (991) for a bit more character without the motorway drone - but at 10+ years old any warranty wasn't going to pay out any way
Went round the houses with options - Quicksilver, Kline, Car Graphic, Tech art, Lichfield etc
All roads went back to Arkrapovick for least hassle/post fitting adjustment requirements etc.
Been very happy with it so far
What squicker said is my experience too. I even extended my warranty with mods on the car - they were declared up front and checked with Porsche GB who signed it off. The same caveat that any claim resulting from a mod will be rejected obviously still applies. Having an OPC who understands the mods, why they were done and what their impact might be is obviously key if a claim has to be made.
The key thing is that both types of warranty are not black/white and on/off. They are looked at on a claim-by-claim basis.
