Adding Reversing Camera to a PCM 3.1 in a 981 Boxster
Tricky54
I want to add a reversing camera function to my 981 PCM 3.1 . I know that there are aftermarket cameras available that fit in the numberplate location, and others that fit centrally to give a true symmetric view and I'm not worried by having to remove the bumper to create a hole to fit it. Which brands and models of camera look like the OEM camera? What are the pros and cons of the various types, which provide gridlines etc. Any advice would be appreciated. I've been told that the cameras fitted on a 987 to replace the numberplate light ie. off centre, have a VW part number and come from a VW T5 van! Is the 981 OEM camera also a standard VW part?
What's the cost of one from an OPC? It costs nothing to ask, I bought a new rear light for my Macan from the OPC, including PCGB discount it was less than half of one advertised on ebay and more recently the frunk liner for my 981 was 40% cheaper from Porsche than @ Design911.
Finally I have a rear view camera attached to the 3.1 PCM in my 981 and the picture is crap (true, better than nothing). I asked if there was anything to be done in the OPC last Wednesday, answer... "no".
Hi Neil1911. Thanks for your post. I gather that you have had a camera added but is it an aftermarket one and is it fitted centrally or to one side above the rear numberplate? What brand? What makes it 'crap'?
I've only had the Boxster since July but I believe the camera is original. The spec is comprehensive, including ACC and PCCBs. My judgement is possibly clouded by comparison to that on my '23 Macan which is crisp and clear, the Boxster's appears "soft focus". I wasn't sure if the lens or the PCM screen were at fault but asked in the OPC, they took a look and said that there's nothing to be done. I'm not necessarily going to leave it at that but it's on pause at this immediate moment. In the medium term an aftermarket Sigma head unit or a Mr Volt add in are options...
As now is: PCCM Plus for Porsche 991.1 / 981 Part No.: 99164260000
It seems I need to revise my earlier response, first the camera is fitted centrally, picture attached, and second it's not as bad as initially thought! The Indy suggested that being located just a few inches above the exhaust it was in prime position to accumulate all sorts of contaminants, so while I hesitated to use wet or dry on it as he suggested, I gave it a good scrub first with paint brush cleaner (great for removing all manner of sticky stuff) then again, without checking the effect, with C-Tec Multisolve (even removes silicone sealant) and...... Hey Presto, clarity restored!
