a bit less yellow
- Thread starter Ewan
Ewan
Bought the new dash board strips and buttons and so forth from Porsche Exeter - nice people to deal with and a good club discount.
Chrishazle
andy watson
Moderator
Interestingly, I used to have the silver inserts and the switch surround in silver, replaced those with brand new inserts, thought it was to bland so had them painted/laquered body colour.
Also replaced the cassette holder with a new oddments pocket and we have the same Kenwood mask!!
Ewan
Andy - the plan with the dial is to revert to normal for the outer two (fuel and battery) but keep the speedo and rev counter yellow. I was testing a California the other day and the way that current Ferraris have yellow rev counters really appeals to me. I'm planing on having Steve do this in a couple of weeks along with a service and a drivers side door lock repair.
Of course, if it looks rubbish I can swap in more standard black dials or just refit the outer yellows. Fun and games.
And having kept all the yellow dash bits they can always be swapped back in at a later date if required.
Copperman05
Edd
andy watson
Moderator
pauljmcnulty
I plan to do all my dash as three bits are cracked, and am going to have them sprayed in the body colour. I think Andy's piano black is spot-on, and my dark metallic grey should work.
Carr looks very nice from the exterior pics BTW. *Will i get scalded for text speak* [
pauljmcnulty
No. But "scolded [
Pedants of the world unite.....
GlennS
ORIGINAL: Ewan
Glen - I replaced all 6 sections of the dash and the total price including delivery and Vat was £90. The bits you mention were about £15 each.
Thanks. I've got a slight crack in one and the other is a bit warped. It is not really noticeable unless you look closely but for £30 it would seem to be worth replacing them.
pauljmcnulty
Depending which bits you need you might want to replace the lot. I changed one on the Lux and it was a noticeably different shade and texture. Didn't show as it was the bit to the right of the wheel, but the others might look odd.
I replaced the long clock trim piece and as Paul said it was black and textured, not brownish and rubbed smooth like the rest of it.
I primered all the trim and sprayed it gloss black anyway so it wasn't an issue really.
