992 Turbo S flat lithium battery. What to do if this happens to you...
Malarcy - my sequence for using footwell 12v socket for Ctek was/is; starting with ignition off, turn ignition on, then turn charger on, wait 1 minute, then turn off ignition & lock car. Ctek's first 3 lights come on and but go no further before error light flashes. This sequence worked OK for 992.1 4GTS but won't with 992.2 4GTS.
Hold the button on the Ctek. It'll change the operation from 'charging' to a constant 12v supply. I haven't used mine in that way, but I'm going to assume after a few minutes you should be able to press the button again and return it to it's normal charging mode. If not, just switch it off at the wall and back on again.
Thanks for the information.
I've picked up my 991.2 and confirmed it's a LiFePO4 battery. I also managed to pickup a CTek XS charger and have connected up the "CTek quick connector/charger" cable using the battery + and earth point on the battery clamp bolt.
On my 997 there was a place in the scuttle panel, where you could run, and hide, the quick connector so that you could access it from outside of a locked car. I am researching something like this on the 991 as it would appear with a flat LiFePO battery you need to overcome two issues, 1. opening the frunk using the fuse board method and 2. perform "defibrillation" to reset a completely flattened LiFePO.
This is from ChatGPT regarding charging LiFePO batteried.
🔋 Key facts about the CTEK Lithium XS and LiFePOâ‚„ batteries​
  1. It’s not a “trickle charger” in the old lead-acid sense.
    The Lithium XS is a smart charger. Instead of continuously feeding current (which would damage a LiFePOâ‚„ battery), it uses an 8-stage program: charging, balancing, testing, and then maintaining with very low current pulses only when needed.
  2. Safe to leave connected long term.
    CTEK explicitly states that the Lithium XS is designed as a “connect and forget” charger/maintainer for 12 V LiFePO₄ batteries. Once the battery is full, the charger switches to monitoring mode. It will only reapply charge if the voltage drops below a set threshold.
  3. Built-in protection for lithium chemistry.
    • No overcharging risk — it stops at ~14.4 V (safe for LiFePOâ‚„).
    • Reverse polarity and spark-proof protection.
    • Can wake up a battery that’s been shut down by its BMS due to under-voltage.
  4. Why this matters for cars
    Modern cars (especially with start/stop and electronics) need a stable, healthy battery. Leaving the Lithium XS connected while the car is parked ensures the LiFePOâ‚„ battery stays topped up without stress or risk of sulfation (which only applies to lead-acid).
âś… Bottom line​
Yes — it is completely safe (and recommended) to leave your CTEK Lithium XS permanently connected to your car’s LiFePO₄ battery. It doesn’t “trickle charge” in the old sense; it intelligently monitors and only charges when necessary, making it ideal for long-term maintenance.
I have also been through the pain of having to work out how to get the bonnet open on my Turbo S having left the car for several weeks without a charger. I have found the NOCO 10 that I have been using has been really hit and miss in terms of whether it will charge the car or not and having come back to it again this week have found the battery is completely flat. I managed to start it using the NOCO boost pack and after leaveing it running for 10 minutes and then putting it on charge, the charger does seem to be working, even with resetting the charger, which may be linked to the comment made by @BigCat about the state of charge affecting the ability for the charger to recognise that it is connected? The question I have though, is how reliable is this battery now going to be on a long trip? The car has not done more than 20 miles a year for the last couple of years with the battery going flat as a pancake several times and now we are taking it on a 1500 mile road trip, so is it worth replacing it, or if it charges up ok, should it be ok as long as I do not leave it too long in between driving stints? Deffo taking the NOCO Boost jump pack with me though and will make sure it is in the car and not in the bonnet!
The lithium battery isn't like a lead acid/AGM, which would be suspect if allowed to 'die' a few times. Instead, the lithium drops to a certain level and the internal BMS shuts it down so it cannot deplete further, thus protecting it from the situation you're describing. Essentially, I believe you will be just fine using it for the long journey you describe.
When I do Euro tours I take a Noco GB50 and leave it in the glovebox (in fact it lives there permanently now) - mainly to be the hero if someone else needs it, but also for the outside chance that I might need it too - and I also have a 2m length of small gauge wire coiled up in the bag. This is to overcome the issue of being able to wake the lithium from the passenger side jump post in the footwell if I can't open the bonnet. When I begin the long plod down to Folkestone, I plug the Noco into the cigarette lighter so I know it's fully prepared for any potential use in anger. So far it's only been used once, and that was to save a delivery driver who got stuck on my driveway!
The solution is to keep the car on a Ctek/similar when not in use (I connect mine religiously after a drive unless I explicitly know I will use it the following day). It does have to be a specific conditioner for lithium batteries though, not just any old one.
As a side note, I have noticed the occasional time when I will connect my Ctek only to find the next day it has a red light and isn't charging. A quick reset and it then seems fine. Whether this is something peculiar with my charger or if it's the battery floating after being used that the Ctek isn't pleased with, I don't know, but I am making it a habit of 'checking in' with the car in the garage a day or two after its last use, just to be certain everything is ok. After this first occasional hiccup, it has been perfect, sometimes for months at a time.
The fact that the fuse box (in which the pull-out plug used to apply power to pop the frunk) is located on the passenger side AND the door cannot be opened when the battery is flat, is, in my mind a fundamental design flaw. If using a typical boost pack, which tend to have short-ish leads, you're screwed. Having been caught out with a flat battery I have learnt this lesson.
In the 997, the internal footwell fuse box was fitted on LH or RH side depending on market. This penny pinching design which probably saved a few quid in part stocks is now typical of Porsche and is the reason I will not buy another when I replace my current ride.
I'm resurrecting this thread with another piece of potentially useful info...
I collected my Turbo S from its 4yr service last weekend and the OPC informed me they'd carried out a software update campaign related to charging. I don't recall exactly what I was told, but it could be related to the numerous battery-related issues that are circling the internet. So if you're having consistent/intermittent lithium battery issues, maybe contact your OPC and ask if there is anything they can do.
I’m writing to thank those above who contributed to the above thread.
I’ve just returned from a month away from my 992.1 Turbo that has a lithium battery. I thought it would be OK without putting it on the CTEK Lithium XS charger.
The day before returning home I got the dreaded call from Vodafone to tell me that the alarm had gone off. They knew however that it was triggered by a dead battery.
Filled with dread about getting it going again on my return, I knew the routine for getting into the luggage compartment, but didn’t know how to restart the battery by holding down the charger reset button for 10 seconds until i googled the problem and found this thread. There was a loud and distinctive click from the battery when the charger reset function operated, and stage 1 light illuminated. I took the terminals off the battery whilst doing this to stop the car’s battery management system from interfering; not sure whether I needed to do this.
After about 5 hours the charger showed it was in stage 7 (float) and so I was able to restart. The dash initially lit up like a Christmas tree with warning messages, but stopping and restarting after a 20 minute drive saw all but the SOS emergency call function warning extinguished, and that in turn disappeared after another short drive.
Again, many thanks.
Martin
