981 Safety Recall
- Thread starter adrianb
Mine charged around £290 if I remember correctly and used S/S replacements rather than mild steel.
Not long after buying the car, a few of the achillies heels of the car came to light, one being these OE mild steel bolts.
As they had been recently replaced by Porsche with OE mild steel bolts M8 x 35mm, I decided to replace them with stainless.
I did this back in August 2017.
I used SS A4 M8 x 30mm socket head button screw "bolts", M8 serrated flange nuts & washers bought from Westfield Fasteners.
Had to replace one of the joints on this flange a while back, 10 minute job with the SS bolts.
I also found one of the rear mild steel exhaust clamps for the tailpipe section badly corroded, in an effort to remove it the strap fractured.
I replaced both the clamps with Mikalor W4 59-63mm clamps.
Other OE clamps I managed to remove the corroded M8 mild steel bolts and replace with M8 stainless button head screws.
filip.baverstock
Sorry to revive an old thread, but my March 2014 registered Boxster 981 rear NS carrier just fractured one of the "ears" which forces the eccentric ring in position as I undid the bolt. I believe this is exactly what this AMB7 sub frame recall is about. The car has fairly low mileage for its age, 54k so I guess the previous owner never ran into this problem. Is the recall bulletin closed? Do you think it is still worth contacting any of the Porsche Dealerships around me (Cambridge area)? Or should I just fix it out of pocket? The part doesn't seem that expensive on eBay (£130ish). I wonder how hard it is to install however. I'm a DIY mechanic.
Needless to say, I am wondering if I should replace the other side too because it makes me feel uneasy about the car's safety now.
Thank you.
I would certainly give Opc Cambridge a call with your reg / vin number to ask the question .
Usually any recall issues are dealt with when in for a service.
Let's us to know the outcome please.
Cheers Cliff
