968 Ducts Fitted
- Thread starter edh
edh
ORIGINAL: TTM
Late turbos and S2's did not have 968 arms.
I would bet your car was fitted with 968 arms during its earlier life - just like mine.
The problem with 968 arms is they aren't easily rebuildable as 944 arms as worn out ball joints cannot be taken out without machining the arm.
968 arms have a 944 part no & PET lists these same arms were for '90 model year onwards 944's. - I had assumed this meant they were fitted from new
John - at least the "ears" are in line with the wheels so will get the max possible ground clearance (and they are very cheap to replace). Later turbos didn't have the ducting through from the bumper, just the deflector on the duct. I think Promax are selling the ducting, but it's 3x the cost of this option. The shape of the upper part looks like it will be pretty good at firing the air into the centre of the disc.
TTM
Well-known member
ORIGINAL: edh
You had assumed right, however :
- The first three figures of the part number are not directly related to the type of car. If you look at specific 968 parts you will also find part numbers starting with "944". Only a handful of 968 turboS/RS parts started with "968". One of our wastegate exhaust gasket begins with 930 IIRC. Although a bit of an extreme example, Turbo Cup cars feature parts beginning with 917 and 965.
- The part numbers listed in PET are often those of the revised part, meaning the part number of the part that was originally mounted on the car cannot be found out by browsing through the various sketches.
Examples : ABS control unit, fuel tank, PS fluid bottle.
ORIGINAL: TTM
Here is a way to fit 968 scoops to 944 arms :
I am no doubt being overly cautious but it isn't something I would be 100% happy with.
Neil Haughey
ORIGINAL: edh
ORIGINAL: TTM
You may find that speed humps are a problem. I found that my car would straddle some humps no problem without the ducts but after fitting them they sometimes catch on the edge of the hump, nasty. Now I slow down and bump one wheel over the hump.
IMHO 968 ducts are brilliant. Pound for pound the best thing I have done to my S2.
edh
One ear is about a tenner - so one of the cheapest 944 parts you can buy [
TTM
Well-known member
ORIGINAL: John Sims
[] I'm not sure I would recommend drilling holes in the lower wishbone. I appreciate that it is a very small hole in, what would seem to be, an unstressed area but all castings have a level of internal stress due to the casting process. I am no doubt being overly cautious but it isn't something I would be 100% happy with.
Fair enough - 968 wishbones are actually strenghtened in the area of the hole.
sawood12
ORIGINAL: appletonn
Scott, what is the 'geometry correcting kit'?
Just wondered...!
Longer ball pins for when you lower the car beyond a certain point which seems to be under debate.
It corrects the roll centre which is affected by lowering (in simplistic terms)
sawood12
Neil Haughey
ORIGINAL: sawood12
Havn't 944 turbo and S2 wishbones got 951 part numbers (I can't be bothered to fire up the PET!). Anyway the 968 wishbones are definately different. They have larger ball joints I think and might be a desirable upgrade. My car actually had a 968 on the nearside and a 944T on the offside. I did a trade with Hartech when I had my geometry correcting kit fitted as it was not suitable for the 968 arms.
Was the same for me. The car had a full OPC history when I bought so I guess they must have fitted the 968 arm thinking it is better or under some direction from Porsche to fit the latter part. I went the other way to you and got another 968 arm to match since the car never handled evenly with the 2 different wishbones despite how much one could fiddle with the caster adjusters.
