944 Turbo Headache odd...No spark
- Thread starter Sweeney2255
Sweeney2255
Sweeney2255
A few obvious suggestions that I'm sure you've already covered, but depending on how long the car has not run for and what was possibly done in the meantime, have you;
Checked the timing on the camshaft markers to make sure all is well and not off by a tooth or two?
Checked condition of HT leads (I had a faulty one with no obvious signs, only noticed as car ran better after replacing!)
Rotor and cap condition
Continuity from DME plug to engine harness (I replaced the ignition wiring with a new one from LR due to possible issues)
Checked all engine ground points for condition and possibly re-fix with vaseline/conductive grease to ensure a good contact.
If you want to pm me an email I can send further details wrt wiring pins to be checked etc.
I went through a no spark issue last year, but I'm running after market ECU as well so possibly different causes to your own...
Sweeney2255
Waylander
has it had a clutch and flywheel change, and the screw not refitted?
the part is 477 105 276 @ ££5.21 and PET lists 3 for the fly wheel, cant imagine why 3 for a 4 pot engine
from pictures and posts on renlist there seems to be different sizes, but PET only lists one, what ever you do make sure its in there with Loctite and lots of it
http://www.arnnworx.com/sensors.htm
Sweeney2255
0.8m is between speed sensor and ring gear
DG on cable is speed sensor
BG reference sensor
D (speed) & B (Ref) should be marked on the housing bracket
Flywheel stud (for ref sensor) screw in with loctite 270 and adjust to 5+- 0.1mm
I can't find / remember if you can adjust reference sensor depth, or if it is fixed, did the ref sensor hit the stud?
Tony
Sweeney2255
Not sure what happened to the old one but was flush ??
Waylander
Sweeney2255 said:So the ref sensor to flywheel stud top is not 0.8mm? its o.5mm?
I read that as the protrusion from the flywheel rather than clearance to the sensor - the 5mm figure was in the engine section (flywheel assembly) rather than the ignition section
Tony
it is in the section about installing it in the flywheel so screw it in until 4.9mm to 5.1mm is exposed. But do you then space the sensor 8mm from the flywheel giving 3mm clearance or 8mm from the the 5mm protruding grub screw? or is the ref sensor not adjustable anyway and setting the speed sensor 8mm sets the ref sensor?Waylander said:Flywheel stud (for ref sensor) screw in with loctite 270 and adjust to 5+- 0.1mm
that means 5mm + - 0.1 does it not, or am I reading that wrong
Tony
peanut
The hall effect sensor registers when a magnetic field passes the sensor , it then emits a electrical signal in the form of voltage every time a magnetic field passes the sensor .
The hall effect ( HE) sensor on the back of the distributor housing senses the position of the cam of each cylinder relative to TDC (half crank speed ) and sends a signal to the ECU which on the Motronic 2.5 tells the ECU which injector to pulse sequentially
The crank TDC sensor on the bell housing is essentially a magnet which creates a magnetic field . When the flywheel reference pin passes the sensor it varies the magnetic field sending the position of TDC to the ECU .The gap from reference pin to sensor is critical.
Later cars have a combined speed sensor and TDC position sensor and use a toothed ring attached to the flywheel.
I think the HE on the back of the distributor is s2 onlypeanut said:Crank speed and hall effect sensors operate differently .
Tony
vitesse
Then removed it & replaced with the new replacement.The speed sensor then fits inside it's shielding aluminium can which fits into the housing & doesn't then need separate adjustment.
