944 TURBO breaking list
nicksonmsport
my 944 turbo is now mainly stripped of its components, only things left on the car are the torque tube, gearbox, and rear suspension/tank. a few little bits and bobs. this will all be removed in due course.
the bodyshell will be available complete with log book, i can provide a full race preperation service for this shell ready for a race car build. i can get it dipped, carry out any repairs, seam welding, full weld in cage, seat rails, harness points, i can also have it painted next door, so perfect for anyone looking for a race car shell for next year etc. please contact for details info@nicksonmotorsport.co.uk
this is a parts list just from a quick scan around the workshop, im sure there is more, and obviously i havnt listed every part down to the last nut and bolt, so if there is something you need and you cant see get in touch, as im sure i will likely have it. i also have a lux that has yet to be stripped.
please make sure you get in touch via email- info@nicksonmotorsport.co.uk rather than pm on the forum as it fills up straight away!
i can post all items apart from large items such as bonnets/bumpers etc
items located surrey gu27
all the items listed are removed from the car ready to post!
all relays/fuses available
full aperture seals, door rubbers/trim etc £50set
turbo plastic undertrays that sit under the front floorpans £10each
front alloy wishbones in good order, later offset type £120 pair
M030 front hubs complete pair £700 pair
ABS sensors front and rear £20 each
ABS pump £100
turbo exhaust manifolds £120 set
turbo crossover pipe £50
turbo oil cooler and pipework to filter housing/duct also available £100 the lot (2 pipes, cooler, duct) can seperate!
turbo engine loom complete £75
turbo front bumper needs paint £25
rear bumper with bump strip removed and smoothed ready for paint £80
turbo engine crossmember £35
turbo engine mounts £40 pair
complete turbo engine block/head/sump etc (rebuilt 60k ago at cost of circa £2600) recent belts, good engine! £1000
power steering pump £50
turbo beru ht lea set £40
turbo struts non M030 with good top mounts £100pair
front impact bar with struts £40
glassfibre front wings pair £120
s2 bonnet in grey £25
complete rear 1/4 panel removed from pass side, includes adjoining panels for perfect repair £120
rear lights £80 pair
wheel nuts, and locking wheel nut set (good set with lock nuts and key) £60
AZEV 17inch wheels, ET15, 8.5J / 10J with goodyear eagle f1 tyres (with ot without tyres) very good rare wheels. centre caps etc
£600 no tyres, £800 with tyres.
fabricated custom aluminium centre console panel £40
door shells, stripped of all excess weight £25 each
clutch master cyl/slave cyl/ and lines £25/25/15
heater pipes/valve
turbo door and rear 1/4 bump strips set £40
door grills x2 £15
rear 1/4 inspection grills x2 £20
starter motor £30
steering column uj good £35
heater control unit £20
full sets of interior switches including window switches/mirror
fuel flap with inner ring and fabric flap £15
porsche script doorhandles £200 (no locks)
full door handle mechanisms/latches etc £40 set
complete lock set with key, door handles, boot, fuel flap, ignition barrel £150
vacum tank £5
battery water catch bottle £5
complete headlights/surround/mechanism £100 the lot
turbo badge panel - needs paint-stonechips £25
alternator £40
turbo metal undertrays £40
steering rack with tie rods (u would need to fit your lines that link across the rack) with tie rods £60
turbo AFM SENSOR £70
high pressure steering hoses £25
ignition coilpack £20
alternator cooling pipework £10
turbo airbox in good condition, one lug has been repaired but u cant see once fitted SOLD
intercooler £75
inlet pipe to airbox
turbo brake ducts, with brackets, and 1 directional scoop for strut (1 missing) £50
turbo ECU pair- std- £300
turbo AMD chipsets, klr and dme, 270bhp, 307ft lb torque £150
MOMO steering wheel boss kit new £50
idle control valve £30
rear brake discs with lots of life £30
non aircon alternator bracket £50
upgraded front door speaker, JBL GTO6427 40w rms, 120 peak £20
rear bumper mounts, as new VGC!
s2 pistons and con rods set of 4 good £150
rear brake disc backing plates ally good £25
turbo instruments clocks/dials £75
brake master cylinder with resevoir £30
M030 FRONT CALIPERS 928 S4, black, stripped, inspected, no plate lift, new plate screws £300
M030 FRONT CALIPERS, 928 S4, RED, fully refurbed, as new ! £400
new rear braided hoses, precision hoses £40
modified turbo inlet manifold, more clearance for bigger turbos (can be used with std setup!) £40
turbo fuel rail/regs (s2 available) £50 for rail with regs
M030 turbo cup rear ARB 3 hole adjustable £250
rear turbo badge £30
radiator fans /s2 radiator £25/60
black sunvisors vgc £30pair
LUX induction filter kit/adaptor and breather £30
working digital clock £80
gear gaitor, black leather VGC £40
bonnet struts good £30
speaker grills beige £20
dash end plates £10 pair
lux toolkit in bag good £30
brand new turbo thermostat housing and thermostat for turbo. part numbers 951 106 313 00 and 951 106 311 00
retails at £4.00 for housing, £28 for thermostat can do the pair for £25 delivered
also brand new turbo, 968, aircon cars radiator fan switch part number on switch 191 959 481c £18 retail , £15 delivered
all prices just a guide, open to sensible offers.
thats the list of main bits available, more s2 parts available as listed in ''massive 944 parts clearout'' thread.
like i say i have a lux that will be broken aswell in the near future
PLEASE EMAIL with any questions, will do sensible prices to clear. pm for pricing, will do a deal on multiple purchases. can post etc.
will likely add to the list. will be adding items to ebay in the new year, but thought i would offer on here first
many thanks
nick
For an S2.... Do you, by any chance, have the plastic cap which covers the hole in the nearside inner wing where the air intake goes on a Turbo car? It is missing from my car and the lack irritates me.
