nicksonmsport
my 944 turbo is now mainly stripped of its components, only things left on the car are the torque tube, gearbox, and rear suspension/tank. a few little bits and bobs. this will all be removed in due course.
the bodyshell will be available complete with log book, i can provide a full race preperation service for this shell ready for a race car build. i can get it dipped, carry out any repairs, seam welding, full weld in cage, seat rails, harness points, i can also have it painted next door, so perfect for anyone looking for a race car shell for next year etc. please contact for details info@nicksonmotorsport.co.uk
this is a parts list just from a quick scan around the workshop, im sure there is more, and obviously i havnt listed every part down to the last nut and bolt, so if there is something you need and you cant see get in touch, as im sure i will likely have it. i also have a lux that has yet to be stripped.
please make sure you get in touch via email- info@nicksonmotorsport.co.uk rather than pm on the forum as it fills up straight away!
i can post all items apart from large items such as bonnets/bumpers etc
items located surrey gu27
all the items listed are removed from the car ready to post!
all relays/fuses available
full aperture seals, door rubbers/trim etc £50set
turbo plastic undertrays that sit under the front floorpans £10each
front alloy wishbones in good order, later offset type £120 pair
M030 front hubs complete pair £700 pair
ABS sensors front and rear £20 each
ABS pump £100
turbo exhaust manifolds £120 set
turbo crossover pipe £50
turbo oil cooler and pipework to filter housing/duct also available £100 the lot (2 pipes, cooler, duct) can seperate!
turbo engine loom complete £75
turbo front bumper needs paint £25
rear bumper with bump strip removed and smoothed ready for paint £80
turbo engine crossmember £35
turbo engine mounts £40 pair
complete turbo engine block/head/sump etc (rebuilt 60k ago at cost of circa £2600) recent belts, good engine! £1000
power steering pump £50
turbo beru ht lea set £40
turbo struts non M030 with good top mounts £100pair
front impact bar with struts £40
glassfibre front wings pair £120
s2 bonnet in grey £25
complete rear 1/4 panel removed from pass side, includes adjoining panels for perfect repair £120
rear lights £80 pair
wheel nuts, and locking wheel nut set (good set with lock nuts and key) £60
AZEV 17inch wheels, ET15, 8.5J / 10J with goodyear eagle f1 tyres (with ot without tyres) very good rare wheels. centre caps etc
£600 no tyres, £800 with tyres.
fabricated custom aluminium centre console panel £40
door shells, stripped of all excess weight £25 each
clutch master cyl/slave cyl/ and lines £25/25/15
heater pipes/valve
turbo door and rear 1/4 bump strips set £40
door grills x2 £15
rear 1/4 inspection grills x2 £20
starter motor £30
steering column uj good £35
heater control unit £20
full sets of interior switches including window switches/mirror
fuel flap with inner ring and fabric flap £15
porsche script doorhandles £200 (no locks)
full door handle mechanisms/latches etc £40 set
complete lock set with key, door handles, boot, fuel flap, ignition barrel £150
vacum tank £5
battery water catch bottle £5
complete headlights/surround/mechanism £100 the lot
turbo badge panel - needs paint-stonechips £25
alternator £40
turbo metal undertrays £40
steering rack with tie rods (u would need to fit your lines that link across the rack) with tie rods £60
turbo AFM SENSOR £70
high pressure steering hoses £25
ignition coilpack £20
alternator cooling pipework £10
turbo airbox in good condition, one lug has been repaired but u cant see once fitted SOLD
intercooler £75
inlet pipe to airbox
turbo brake ducts, with brackets, and 1 directional scoop for strut (1 missing) £50
turbo ECU pair- std- £300
turbo AMD chipsets, klr and dme, 270bhp, 307ft lb torque £150
MOMO steering wheel boss kit new £50
idle control valve £30
rear brake discs with lots of life £30
non aircon alternator bracket £50
upgraded front door speaker, JBL GTO6427 40w rms, 120 peak £20
rear bumper mounts, as new VGC!
s2 pistons and con rods set of 4 good £150
rear brake disc backing plates ally good £25
turbo instruments clocks/dials £75
brake master cylinder with resevoir £30
M030 FRONT CALIPERS 928 S4, black, stripped, inspected, no plate lift, new plate screws £300
M030 FRONT CALIPERS, 928 S4, RED, fully refurbed, as new ! £400
new rear braided hoses, precision hoses £40
modified turbo inlet manifold, more clearance for bigger turbos (can be used with std setup!) £40
turbo fuel rail/regs (s2 available) £50 for rail with regs
M030 turbo cup rear ARB 3 hole adjustable £250
rear turbo badge £30
radiator fans /s2 radiator £25/60
black sunvisors vgc £30pair
LUX induction filter kit/adaptor and breather £30
working digital clock £80
gear gaitor, black leather VGC £40
bonnet struts good £30
speaker grills beige £20
dash end plates £10 pair
lux toolkit in bag good £30
brand new turbo thermostat housing and thermostat for turbo. part numbers 951 106 313 00 and 951 106 311 00
retails at £4.00 for housing, £28 for thermostat can do the pair for £25 delivered
also brand new turbo, 968, aircon cars radiator fan switch part number on switch 191 959 481c £18 retail , £15 delivered
all prices just a guide, open to sensible offers.
thats the list of main bits available, more s2 parts available as listed in ''massive 944 parts clearout'' thread.
like i say i have a lux that will be broken aswell in the near future
PLEASE EMAIL with any questions, will do sensible prices to clear. pm for pricing, will do a deal on multiple purchases. can post etc.
will likely add to the list. will be adding items to ebay in the new year, but thought i would offer on here first
many thanks
nick
ABS pump £100
heater pipes/valve
door grills x2 £15
starter motor £30
vacum tank £5
alternator £40
intercooler £75
many thanks
nick
