94 Turbo
- Thread starter nickhouse
simkin911
edh
a 90k miles car on original suspension / wastegate etc.. will be nowhere near as good as Nick's old one. There's a big difference in the power delivery of a car with a standard / tired wastegate, and one with just a simple boost enhancer, or better still a dual port wastegate. It's not so much about maximum power (although that helps), but more about extra mid range torque, and much faster response.
Lots of things on these cars will cost ££ to put right - much better if the previous owner has done it. Aircon, suspension & bushes, clutch, sills, etc..
I think Nick's old car had the seats re-connolised didn't it?
I think dampers/bushes last around 100k / and the gear linkages similar - The rest can show minimal wear after 200k - the seats sag a bit/ the stalks gain some looseness and the front glass (windscreen / headlights) will show some sandblasting.
Wheel bearings 150k ish all though this may be age related and standing around on them wont do them much good either. Electrical bits and pieces probably suffer as much lack of use (corrosion) as they do from wear except maybe the alternator, mine was good for around 180k. The turbos themselves can fail, between 80 and 200k but probably from misuse or ingesting foreign objects - the metal pipe under the inlet manifold is known for collecting scale/carbon and it exits in front of the turbo inlet.
Wastegates have an effect on performance and these may suffer from heat more than corrosion - however if you want to extract the true potential from a turbo these are one of the first items to go.
So condition over mileage would be my advise (they had a reputation for being clocked when newer anyway - built to last so don't show wear)
Good luck
Tony
Tony
Andrew Mearns
944 man
OP, it would be a mistake to buy strictly on mileage: which you seem determined to do. Its the condition and the service history bills that matter. Only when you have found two identically well maintained and equally rust free good condition 951s, should mileage become part of your decision making process.
Congratulations.
I love them !!!
A guy on TIPEC Selling a lovely Red Turbo with bluprint engine, up on the miles but in super condition, with all the right bits 300+ bhp inner pictures of the sills which are as new, a brilliant starting point.........................do not be put off by miles as already said.
Suffolk944
Moderator
ORIGINAL: nickhouse
Yes i still have the RS2 and the others.
Think I have just turned "Ragus Green" with envy ! [
