So I got my car on a free dyno run the other day courtesy of Powerstation in tewkesbury.
My 1984 2.5 8v produced 148.4HP and 160lbf/ft. Pic of the dyno printout is a bit blurry from my phone but you can see the results if you zoom in.
http://picasaweb.google.co.uk/tomspics1234/944Dyno#5274910186676501474
Now im looking at tuning the engine and I was thinking first about changing the cam's and sorting out the DME with a late model+AFM and a remap. Im not looking to build a race engine and the car will be my daily driver so I would just like some more top end power and possibly a higher rev limit.
Can anyone confirm what the cam overlap is on my 944, I've heard its about 3 degrees. The dyno results show the car produces peak torque from about 2k rpm which along with the power drops off about 5k rpm. This would suggest to me that the gas flow is becoming an issue at higher rpm's. Any experience with changing the cam's would be appreciated. Im aware I will have to sacrifice some low end torque for this if I go down the cam route, and prob some economy. Any suggestions on how much overlap to use? I have an original cam I was thinking i could get re-ground.
I understand the early DME's do not have an EEPROM so cannot re-mapped. Fortunately I have a late model DME and AFM avaialble to me which from what I can tell can replace the parts on my car allowing it to be re-mapped. This would seem to be the easiest course of action, however I was wondering about aftermarket management systems. I would imagine this would be rather expensive to implement compared to a free late DME+AFM. Would it yield any sigificant benefits?
Tom
Tom
