2017 Macan SD - Steering/Transmission Issue
Perksy
Hi all,
This week my 2017 Macan SD developed a strange sound from the front when cornering/maneouvering at low speed. The best way to describe the sound is like a coin rattling around in a washing machine, not a constant rythmic tapping that you might expect from a rotating wheel, more random than that. Has anyone else experienced anything similar? Hoping I can narrow down the diagnosis before approaching a garage.
Has it suddenly developed or occurred gradually? Does it happen on one lock or both?
Could it be gravel lodged in a front calliper or wheel? Have you tried reversing to dislodge it.
Does it just happen when moving or can it be replicated when stationary?
Few things to consider when trying to narrow it down.
It could be something internally like a lack of hydraulic fluid or defective power steering pump, but it would be best to eliminate all the exterior factors first.
Regards,
Clive
Regards,
Clive
Hi Lancerlot,
I first noticed it a few says ago. I can’t say I noticed a gradual occurrence. It seems to be when moving and the steering wheel can be at any position. I reverse park twice a day so I think anything stuck would have been dislodged by now. The ‘tumbling coin’ noise only happens when moving and seemingly only at slow speeds, I haven’t noticed it at higher speeds, say 25-30mph. The transfer box was replaced under warranty a couple of years back and it isn’t the same symptoms, I.e. no ‘wheel jump’ sensation. I’ll check fluid level later too.
Thanks 👍.
The only other obvious component would be indication of a defective wheel bearing. Lift each front wheel off the ground in turn, hold the wheel at 12 and 6 o'clock and check for any play, do the same at 0.15 and 0.45 o'clock. Then rotate the wheel and listen for any grinding, roughness or other metallic noises.
Please report back once the fault has finally been located as it all adds to general knowledge pool.
Regards,
Clive
I wonder if the back plate / dust shield has come loose? You should be able to get a hand through the wheel to check.
A loose heat shield can rattle randomly, perhaps at specific frequencies when the engine is running under different loads. (I experienced this on a car after driving through a flooded section of road - an underbody heat shield was dislodged by the water causing a random rattle)
I believe the Macan has a number of heat shields in the engine bay to protect from the heat of manifolds and turbos, including heat shields to protect suspension elements - if a clip comes loose or corrodes these might rattle
So. I booked the car in to Kent Porsche, Swanley, and the issue was diagnosed to the front nearside driveshaft. Replaced and ready to collect within five hours! Great service from the guys there, highly recommended.
