18" wheels question
- Thread starter RSGulp
There may well be a case for fitting it due to the extra forces which may be generated with the increased grip of the larger wheels, especially on track. However if you are only going to push the car in and out of the garage to polish off the wax out of the sunlight, you may well get away with not fitting it! [
ORIGINAL: clubsport
Rich, I wouldn't bother with the bracket.
There may well be a case for fitting it due to the extra forces which may be generated with the increased grip of the larger wheels, especially on track. However if you are only going to push the car in and out of the garage to polish off the wax out of the sunlight, you may well get away with not fitting it! []
![Kiss [sm=kiss.gif] [sm=kiss.gif]](/forum/styles/default/pcgb/kiss.gif)
ORIGINAL: clubsport
Rich,
Try this...
1. support bracket - 993.347.131.02
also required;
2. allen bolt - M8x60 (Qty. 2) 999.218.102.09 - M8x60 bolts
3. allen bolt - M8x80 (Qty. 2) 999.218.103.09 - M8x80 bolts
The allen head bolts are torqued to 32.5 ft-lbs.
Thanks for your help Paul - where do you get this information?
I've looked around and it seems I can buy a €45 kit from the likes of Carnewal which contains the bracket and 2off M8x80mm bolts. I assume these replace the 2off M8x60mm bolts which are already on the car. To clarify, I think only need to get the bracket and the 2 longer bolts? - #1 & #3 on your list
EDIT: JUST FOUND THE ANSWER TO MY QUESTION...
In traditional "dottenzie i's undcrossenzie t's" Porsche fashion, the 2off M8x60mm bolts are to replace those (I guess 'use once only') that may have to be loosened to allow the bracket to be installed.
Technical bulletin available here: http://forums.rennlist.com/rennforums/attachments/964-forum/366054d1245503624-18-wheels-for-de-tech-bul-9604.pdf
ORIGINAL: clubsport
Bwahahahahaha!!!! Like yer work Paul!![
ORIGINAL: Melv
Google is a wonderful thing.............[&:]
http://www.amazon.co.uk/Porsche-911-Enthusiasts-Companion-1989-1994/dp/0837602939/ref=sr_1_4?s=books&ie=UTF8&qid=1290888604&sr=1-4
It is, as is Amazon --- bought my first thing from them last month and was very impressed.
Just thought that the club might do a roaring trade in such bits n' pieces .. [8D]
