Helpful Reply718 Cayman N Rated Tyres
John52
John52 PCGB Member
2023/04/29 14:55:39 (permalink)
I own a 2018 718 base Cayman with Dunlop SP Sport Max GT N0 tyres but I want to change to Michelins if possible. I had some bad experiences with the Dunlops last December on the packed snow with virtually no braking at all from them at very low speeds approaching junctions, hence the need to change before the next winter.
Unfortunately I have only found Pirelli & Goodyear N rated replacement tyres which some reviews don’t rate as highly as Michelins. I would be grateful if anyone can suggest any Michelin N rated tyres for the 245x45x18/265x45x18 tyres I currently run. Thanking you in advance for any help you can give. Cheers, John
List Solutions Only
Motorhead
Motorhead PCGB Member
Re: 718 Cayman N Rated Tyres 2023/04/29 15:18:25 (permalink)
Hi John,
I don’t believe that you’ll find any Michelin N-rated tyres in those sizes, especially MPS4S or MPS5.
If you have the Porsche Extended Warranty then you have to have N-rated tyres for the warranty to be valid, so you’re stuck with the approved Pirelli and Goodyear tyres. If your car isn’t under warranty then you have a free choice, and although the MP4S4 appears to be the tyre of choice the Goodyears have their supporters if you’re not keen on the Pirellis.
987.2 Cayman S
North Beds (R10 & R24)
Wollemi
Wollemi PCGB Member
Re: 718 Cayman N Rated Tyres 2023/04/29 15:19:41 (permalink) ☄ Helpfulby John52 2023/04/29 20:12:03
I believe that your front size should be 235/45/18, but nonetheless it appears that the only N rated tyres are The Goodyear F1 Asymmetric N0 or the Pirelli P-Zero N; both of which are excellent tyres.
But one thing to note is that all of these of tyres, and the Michelin PS4S (which isn't available in your size), are utterly terrible on snow; in reality none of them are meant to be used below 7°C.
If you want to be able to drive on snow or just wet roads in winter then you need a set of winter tyres.
Graham - R7 Yorkshire CoG member
membership no 62684
718 Boxster GTS 4.0 PDK (2021) Python Green
previous
718 Boxster GTS 4.0 Man (2020) Aventurine Green
2009 Boxster S (987.2 ) - Meteor Grey
Motorhead
Re: 718 Cayman N Rated Tyres 2023/04/29 15:29:18 (permalink)
+1 on Graham’s comment about using summer tyres during the winter. Quite a few owners buy a set of wheels and tyres for winter use to avoid the faff of having to swap tyres.
987.2 Cayman S
John52
John52 PCGB Member
Re: 718 Cayman N Rated Tyres 2023/04/29 20:33:38 (permalink)
Many thanks Jeff & Graham for your advice. And sorry for getting the wrong size for the fronts as well! It was reassuring to hear that the Pirellis, Goodyears, Dunlops & the Michelins are   pretty bad on the snow as they are basically summer tyres only and that I need to think about buying some winter tyres instead. I have never experienced the no braking effect I had on the snow last December & that was very disturbing. Maybe it’s all because there is little weight over the front wheels. I don’t really want to contend with having a set of summer & winter tyres but think I may have to have some winter tyres now for a car like the Cayman. Could I ask which N rated winter tyres you would recommend. And can I ask what do you think about the Michelin CrossClimate 2 all season tyres as an alternative idea. Sadly they are not N rated. Many thanks again. John
Motorhead
Re: 718 Cayman N Rated Tyres 2023/04/30 10:44:05 (permalink)
Unfortunately I don’t have any experience of winter tyres John, so can’t provide any direct advice, but this link may be of some use:
https://www.porscheclubgb.com/forum/tm.aspx?m=1067050
I would think that winter tyre offerings from the major players - Goodyear, Michelin and Pirelli - would be a good choice, although I’m sure that there will be many others.
I don’t recall anyone on here mentioning that they’ve fitted all season tyres for year-round use. Although I’m sure that they would be good for winter use, it’s likely that they will compromise handling for summer use … which surely is one of the main reasons for purchasing a sports car! The fact that Porsche currently don’t have an N-rated all season tyre indicates that they agree.😀
987.2 Cayman S
John52
John52 PCGB Member
Re: 718 Cayman N Rated Tyres 2023/04/30 12:47:39 (permalink)
Thanks again Jeff for your advice & point taken about the all season tyre option. It makes sense! I will contact my OPC to find out about approved winter tyres.
I have now come to the conclusion that Boxster/ Cayman owners should always use winter tyres in cold conditions to avoid the scary no braking experiences I suffered from last December on the snow. Cheers John
Wollemi
Wollemi PCGB Member
Re: 718 Cayman N Rated Tyres 2023/04/30 12:48:17 (permalink)
Michelin Cross climate tyres or their competitors (eg the Hankook Kinergy 4S) are great.
On normal shopping cars.
Not for sports cars I’m afraid.
I have the Michelin Alpin PA4 N0 on 19” wheels, these were supplied as package by Porsche.
post edited by Wollemi - 2023/04/30 14:52:41
membership no 62684
previous
Greenman986S
Greenman986S PCGB Member
Re: 718 Cayman N Rated Tyres 2023/04/30 12:52:04 (permalink)
A second set of wheels, with winter tyres, is cheaper than daily winter car..at least according to my man math.
Depending on when your car visits your OPC, does it really need N rated winter tyres?
post edited by Greenman986S - 2023/04/30 12:53:15
Wollemi
Wollemi PCGB Member
Re: 718 Cayman N Rated Tyres 2023/04/30 15:11:36 (permalink)
Greenman986S
only that it’s surely better to have winter tyres that have been developed for your car, so you know will work well in it.
Got to be better than pot luck?
membership no 62684
previous
Greenman986S
Re: 718 Cayman N Rated Tyres 2023/04/30 19:02:17 (permalink)
Maybe....but the OP doesnt rate the  Dunlop SP Sport Max GT N0....
we all make our choices
Wollemi
Wollemi PCGB Member
Re: 718 Cayman N Rated Tyres 2023/05/01 17:44:19 (permalink)
Greenman986S
To be fair he doesn’t rate their performance on snow
membership no 62684
previous
John52
John52 PCGB Member
Re: 718 Cayman N Rated Tyres 2023/05/01 23:48:48 (permalink)
The Dunlops were truly hopeless in the snow, hence my need to find a solution before the next winter. A set of winter tyres is the obvious way to have total reassurance in cold conditions but if I stick to the convenience of having just one set of tyres could anyone advise if the Pirelli and Goodyears could be used in the cold. I can’t imagine they would be as useless as the Dunlops were & I would imagine there must be many Boxster/ Cayman owners who have used them in the cold with some success. To me I think it is unacceptable that Porsche sell these cars with Dunlops knowing that in cold conditions there will be very limited braking from them.
BrianJ
BrianJ PCGB Member
Re: 718 Cayman N Rated Tyres 2023/05/02 11:17:28 (permalink)
Pirelli P-Zero tend to get somewhat slated but my experience (on 20" wheels) is that the original N0 were poor but the latest N1 are completely different and much better both for wet grip, particularly when cold, and also for ride. Whilst the recommendations above to use winter tyres in winter is the right one, particularly for a daily driver, I was caught out coming back to Derbyshire from Wales about 18 months ago on "summer" tyres in a massive snowstorm with lots of closed roads and a completely snow-covered road surfaces for several hours of driving, albeit rather slowly. I was actually quite surprised that I was able to keep going, steering (and stopping) in circumstances that I thought would defeat my Pirellis completely. My first Boxster was a 986 daily driver - that was very scary in snow on the then current Michelin "summer" tyres. I have had Goodyear Vector 4Seasons on a previous Audi Q3 which were completely amazing up the Cat and Fiddle (if you know that) in a blizzard - just ploughed through everything without losing grip at all, but all-season tyres are not suitable for Porsche sports cars.
I would concur with the above that if you want the best for winter, buy a set of winter wheels and tyres, but beware buying cheap ones off ebay - many look unused but are ancient tyres which should be on the scrap heap. If you buy "summer" tyres (such as Pirelli) make sure you get the latest N rating for your wheel size, because eg N1 on 20" wheels are not the same as for 18" or 19" which may have more generations of N. And if you buy Pirelli, don't forget the PCGB offer (see PP ad and discounts on web site) which only applies at OPCs and Pirelli Performance Centres.
Brian J
First 2003 986 Boxster 2.7 facelift Tip, Orient Red
Then 2009 987 Gen II Cayman S, Basalt Black.
Next 2013 981 Boxster S PDK, Agate Grey.
Now 2016 981 Boxster S PDK, Guards Red.
Derbyshire Peak District
MrDemon
MrDemon PCGB Member
Re: 718 Cayman N Rated Tyres 2023/05/02 13:12:06 (permalink)
Wollemi
not sure where you got the 7oc from this is for a cup2 tyre a PS4S still outperforms a winter tyre at 3oc.  and P zero are utter **** tyres lol imho.
Radio ? NONE.
Cup Holder? NONE
Air Condidioning? DITTO
A pure roadster. Reduced to the essentials
Still the fastest...
AndrewCS
AndrewCS Guest of the Club
Re: 718 Cayman N Rated Tyres 2023/05/02 13:39:31 (permalink)
John52
I assume that it`s your daily and that you `have to` use the car in such conditions ?
Cold conditions and snow conditions are quite different, you can expect - within reason - Summer tyres to manage the cold but not the snow
Have you tried turning the traction control `off` in snow conditions, it `usually` helps ...
Previous : Cayman R - Cayman 981 S PDK - Cayman 981 GT4 / Current : Audi B5 S4 Avant - BMW M2 (OG) DCT
Nigel Trundle
Nigel Trundle Guest of the Club
Re: 718 Cayman N Rated Tyres 2023/05/06 22:35:40 (permalink)
John52
Many thanks Jeff & Graham for your advice. And sorry for getting the wrong size for the fronts as well! It was reassuring to hear that the Pirellis, Goodyears, Dunlops & the Michelins are   pretty bad on the snow as they are basically summer tyres only and that I need to think about buying some winter tyres instead. I have never experienced the no braking effect I had on the snow last December & that was very disturbing. Could I ask which N rated winter tyres you would recommend. And can I ask what do you think about the Michelin CrossClimate 2 all season tyres as an alternative idea. Sadly they are not N rated. Many thanks again. John
I have used Michelin Pilot Alpin and would highly recommend as they are far superior to Pirelli Zero when temps are below 15 degrees in any weather conditions! They really add to the enjoyment of the car for half the year!
Wollemi
Wollemi PCGB Member
Re: 718 Cayman N Rated Tyres 2023/05/07 11:17:05 (permalink)
MrDemon
Where did I get it from? Well Porsche say:
The driving performance and comfort of summer tyres deteriorate at temperatures below 7 °C. Porsche therefore recommends changing to winter tyres when temperatures fall below 7 °C.
And Michelin say:
Summer tyres are designed to be used during warmer months when temperatures can reach up to 40°C on occasion or even extended periods of time, or throughout the year in places without winter weather. With a shallower tread pattern and a stiff, sticky tread compound that offers excellent grip on dry and wet surfaces, summer tyres are specifically designed to deliver optimal performances in temperatures above 7°C. They maximize precise handling and make sure you’re as stable as possible when turning corners or braking.
And for clarity Michelin class the PS4S as a Summer tyre.
Now it could be that that you are right David and both Michelin and Porsche are wrong. You tell 'em!
Further more it is manifestly complete bollox to say that the current P-Zero is crap. You may have a preference, as I do, for the PS4S but the current P-Zero N1 is a very capable tyre.
post edited by Wollemi - 2023/05/07 11:21:51
membership no 62684
previous
MrDemon
MrDemon PCGB Member
Re: 718 Cayman N Rated Tyres 2023/05/09 19:28:06 (permalink)
they are in the tyre selling game so not as clear cut as you might expect.
real world top summer tyres like the class leading PS4S for the most part outperform winters at even low temps in the dry. snow is another story of course.
even at 0oc if its dry the PS4S will beat the other Winter tyres.  UK roads are mostly dry I find. At 2oc the PS4S is a clear winner on a dry road.
If it's wet and cold then yes 7oc seems the change over point where a winter will out brake a summer just.  But again we have more dry days than wet days in the UK even in winter !  and unless you live in scotland and work at 5am I would stay with PS4S is safter more of the time.
The thing here is if it's very wet you can drive slower on a PS4S for that odd wet standing water road day,  but if it's dry and you are on a winter tyre even at 0oc you are risking your life for the worse on a ****ter tyre for the weather :-( as I doubt people will drive slower if it's dry !!!
Winter tyres just don't work in the UK its too hot. hence the cross climate type tyre.  In Finland it's a differeant story ;-)
if it snows for that one UK day a year I stay at home.
post edited by MrDemon - 2023/05/09 19:30:08
Radio ? NONE.
Cup Holder? NONE
John52
John52 PCGB Member
Re: 718 Cayman N Rated Tyres 2023/05/16 09:19:00 (permalink)
Thank you all for your replies.As I don’t want to have the palaver of having summer and winter tyres I have decided to just have summer tyres and not to drive on the days when we have snow. It is too scary to drive on snow with my current Dunlops. Before our next winter I will buy a new set of Pirellis and just accept their limitations in cold/snowy conditions. I wish Michelin had produced some all-season tyres for the Boxsters and Caymans like they do for my wife’s Macan as those tyres provide complete confidence in all conditions.
