Advice please
Bungditin
Bungditin Guest of the Club
2022/10/28 11:24:06 (permalink)
Advice please
Hi there
ive got the engine out atm, and I was wandering about doing other stuff while all is accessible.
any advice is much appreciated
mcgc0
mcgc0 PCGB Member
Re: Advice please 2022/11/01 12:38:33 (permalink)
How much money do you have or want to spend is the main question? Typically looked at and suggested by OPC or indies;
- Clutch/Flywheel condition (upgrade options too)
- Thoroughly trace any obvious oil leaks and fix (seals, gaskets etc)
- Cam chain covers (often a slow leak - not critical, but engine's out, so..)
- Any steering pump seal leaking
- Valve cover seals/gaskets
- Engine tinware and heat shielding (I had all tinware blasted then powder coated - loads cheaper than brand new)
- Heat exchanger condition (especially the flange connection to the exhaust/catalyst pipe)
Maybe think about fuel injector servicing and recalibrating (again, how much money?). Others might chip in too..
'90 964 C4 Velvet Red
'94 968 Sport Gaurds Red
'90 964 C4 Slate Grey
'08 Golf Mk 5 GTi Black
turbo jonny
turbo jonny PCGB Member
Re: Advice please 2022/11/02 13:21:33 (permalink)
Check fuel lines
valve adjustment as well as gaskets
1992 964 C2 WTL Guards Red
2015 981 Boxster S Sapphire Blue
964turbo36.co.uk register and website
mcgc0
mcgc0 PCGB Member
Re: Advice please 2022/11/02 16:37:51 (permalink)
point of note being that not all these items can only be done with engine out. Three ways t look at this; some items only done if engine out (gearbox/clutch/tinware, some heatshields, cam chains etc), other items are easier to access or asses with engine out (e.g. fuel lines, valves, valve covers etc) and the rest can be done with engine in but small hands ideal. Hope that hgelps..
