Advice please
- Thread starter Bungditin
- Clutch/Flywheel condition (upgrade options too)
- Thoroughly trace any obvious oil leaks and fix (seals, gaskets etc)
- Cam chain covers (often a slow leak - not critical, but engine's out, so..)
- Any steering pump seal leaking
- Valve cover seals/gaskets
- Engine tinware and heat shielding (I had all tinware blasted then powder coated - loads cheaper than brand new)
- Heat exchanger condition (especially the flange connection to the exhaust/catalyst pipe)
Maybe think about fuel injector servicing and recalibrating (again, how much money?). Others might chip in too..
turbo jonny
valve adjustment as well as gaskets
