Helpful ReplyHot!Driver’s window not returning to closed position
Raveydavey
Raveydavey PCGB Member
2021/08/16 06:45:20 (permalink)
hello all. Recently noticed an issue. when I unlock and move the door handle to open the car the window opens slightly as it should, but When I close the door the window doesn’t return to fully closed position. In order to close it probably I have to put the ignition on to start, use the window control button on the door.
I also have a possibility related issue with the same window when trying to close it: I have to hold the button up until closed. passenger window works fine: hold for a second and it closes automatically.
anyone seen this before? It’s still under warranty so will take it in unless this there’s a quick fix? TiA
Ledlights
Ledlights PCGB Member
Re: Driver’s window not returning to closed position 2021/08/16 08:15:26 (permalink) ☄ Helpfulby Raveydavey 2021/08/16 09:28:28
Raveydavey
Resetting the window may fix it. Try the following:
To reset (car must be on):
1) lower window all the way down and release switch
2) push switch down, hold it down for 3 seconds, and release
3) raise window all the way and release switch
4) pull switch up, hold it for 3 seconds, then release
5) turn car off and back on
Hope this helps,
Steve
Raveydavey
Re: Driver’s window not returning to closed position 2021/08/16 09:28:57 (permalink)
Ledlights
Raveydavey
Hope this helps,
Steve
Thanks. I'll give that a go later.
911Time
911Time PCGB Member
Re: Driver’s window not returning to closed position 2021/08/23 10:55:30 (permalink)
Just to add to the helpful reply about re-setting your window's stop positions: These sort of 'memory' settings and stored adaptation values, can be affected by either the battery having been disconnected, or having low charge. Something to bear in mind, if a vehicle only has occasional use and isn't connected to a Porsche/Ctek battery conditioner.
Mark
Member: 141540
2013 991.1 4S with a few 'Special Bits'
https://www.facebook.com/MarkDavis911Time/
JimB976
JimB976 PCGB Member
Re: Driver’s window not returning to closed position 2021/09/13 08:48:17 (permalink)
To agree with the last post, I tried the reset on my previous 991 and it temporarily worked - the window returned to the close position.  After it soon 'lost' its memory again I returned to my OPC to look at the car under an intended warranty claim and they quickly identified the car required a replacement battery (for my account, obviously!)
Garage:
992 Carrera S - Gentian Blue
991.1 Carrera GTS - Jet Black
993 Carrera - Aventura Green
992 Register Secretary (South)
