Helpful ReplyHot!Some Advice Please Guys & Gals, with this COVID19 and we cant drive
Page: 12345.. > >> Showing page 1 of 11
Nick7602
Nick7602 Guest of the Club
2020/03/25 14:05:50 (permalink)
Hi Guys
Please excuse me, im very new to Porsche ownership, as we can no longer drive our beloved cars, what would you guys do for the long term? currently Im starting the car everyday and letting it idle until the temp gauge shows normal operating temperature then turning it off
this is probably the wrong thing to do?.....I have toyed with Idea of removing the battery but I do not have the codes for the infotainment, and im unsure what would happen if I connected the battery again?
Sorry guys im a newbie
thanks for reading
Nick
post edited by Nick7602 - 2020/05/02 12:35:40
List Solutions Only
Twinfan
Twinfan PCGB Member
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 14:10:56 (permalink)
As long as your battery is good, your car will be fine to leave for at least 2-3 weeks.  I plan on leaving mine alone and just using it every 2-3 weeks to go shopping in instead of using my wife's daily driver.
Nick7602
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 14:40:27 (permalink)
Hi twinfan
Thank you for responding, regarding the battery I have been using a CTEK charger to maintain the battery as I personally do not know the age of the battery, I think I might do the same Twinfan and go shopping in the Porsche, I will replace the battery at some point when the current crisis drops sufficiently to allow me to go and get a new one
Im also wondering what happens if I do replace the battery?
Kind Regards
Nick
Twinfan
Twinfan PCGB Member
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 14:46:30 (permalink)
Depending on your model of Cayman, I believe the more recent ones need a trip to an OPC or Indy to code the battery to the car otherwise you get warning lights/error codes/parts not working.
If you're on a CTEK there's certainly no need to start the car every day.
DWaldie
DWaldie Guest of the Club
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 14:52:06 (permalink)
I'm a key worker so have an excellent excuse to use the weekend car through the week. If you're in South Yorkshire, I'm happy to give yours some excercise 😀
Seriously, I use a cheap battery conditioner from Amazon and have left mine at least three weeks without a problem.
DWaldie
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 14:57:53 (permalink)
Twinfan
OPC simply add the serial number to the computer so it is covered by the warranty. From posts on this site and others, Porsche will still exclude the battery anyway, and the car cannot tell one gel battery from another.
Twinfan
Twinfan PCGB Member
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 15:07:21 (permalink)
I don't believe that's the case for 981/982 series cars, the battery has to be coded to the car using PIWIS to ensure full functionality is maintained.
ralphmusic
ralphmusic PCGB Member
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 15:12:23 (permalink)
On my old 981CS, I bought a new Banner battery from Design911 and had it fitted by my Centre. They said I would get errors as they could not code it (enter a new battery and serial number into the ECU so it could run the calibration).
I had no error messages, no loss of functionality, no over or under charging of battery. Whether non-coding reduces the effectiveness of the in-use charging regime and therefore longevity of the replacement battery, I have no idea but it was still OK after 4.5 years
Modified Register - Asst RS
modified@porscheclubgb.com
R15 Devon
12 - RSRTC
Nick7602
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 15:36:37 (permalink)
Thank you very much for replying guys its very much appreciated.
The car is a 987.1 Cayman S Sport, I have had to use a CTEK charger to recon the battery, I cant leave the charger on the car due to the garage being to small and having to charge on the drive, I will drop down to Cotswold Porsche and get the guys to fit a new battery for me,
By the way guys is it normal for a cayman to crank about 4 times to start??
Again thanks for reading......... and please everyone stay safe in these challenging times..........hopefully I will get to meet some of you after all of this at a meet, I live in Worcestershire....
Kind Regards to all
Nick
Twinfan
Twinfan PCGB Member
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 15:50:16 (permalink)
My old 981 CGTS and current 718 GT4 fire(d) up immediately, so it sounds like your battery may well be on the way out.
Nick7602
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 15:55:40 (permalink)
Mmmmm I thought it might be Twinfan, not being used to the car and not knowing enough about her I did wonder, then its definitely off to get a new battery......thanks Twinfan
Kind Regards
Nick
DWaldie
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 16:31:13 (permalink)
Assuming you don't have an OPC warranty, Halfords do a gel battery to fit my (981) Cayman S for £142 with a five year warranty. £25 for fitting. And they are still open. OPC will charge about 4X that with a two year warranty.
ralphmusic
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 16:40:34 (permalink)
My local Halfords has closed, I would thought it was all their stores.
R15 Devon
12 - RSRTC
jmaddox
jmaddox PCGB Member
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 16:45:32 (permalink)
Have just read that Halfords are arranging to open again.
944 - gone
924S -gone
944 Turbo - gone
993 Carrera - gone
Cayman S - gone
997 Carrera
DWaldie
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 16:54:27 (permalink)
Just had a CEO message from Halfords to say they will be staying open as an essential service. Best to check their website tomorrow. Good luck
CLIFFWILKINS
CLIFFWILKINS PCGB Member
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 17:25:51 (permalink)
Running a car at idle for 20 minutes is probably not doing  it  any good without any load l put my CR away for 3 or 4 months in the winter with a CTEK  connected up looks like it may be a little longer this year.
When ready for action  I just fire it up without any problems.
Assistant Register Secretary
Following: @BoxsterRegister
Current cars
Cayman R Peridot
Boxster 981 GTS White
Previous
GT3 Mk 2
GT3 Mk 1 S/Y Missed
Cayman Sport Viper Green
996 4S
4 986 Boxsters
987 Boxster
3.2 Carrerra
944 &924
A8 SPY
A8 SPY PCGB Member
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/25 19:58:32 (permalink)
As I had a heart Op last week I'm unable to drive for a while plus these Virus restrictions. I've purchased a Solar 40w panel + controller as I don't have access to mains power for a C-TEK, it will sit on the dashboard and comes with a lighter socket adaptor as an extra.
post edited by A8 SPY - 2020/03/25 20:02:04
Cargraphic Cayman R Power kit 4 with Cargraphic 200 cell cats and manifolds Techart exhaust tips
BMC Sports Air filter
Sus...art front radiator grille set,
XPEL Paint protection film over bumper and bonnet,
Gtechniq ceramic hydrophobic coating(457 > max. 255)
Peter_Bull
PCGB Honorary Member
Peter_Bull PCGB Honorary Member
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/26 08:10:32 (permalink)
Nick7602
Have i missed somthing?  Never heard of this model.
Forum Administrator
Honorary Member since 1998
2014 Cayman 2.7 PDK Racing Yellow
2019 BMW 4Series Convertible M Sport Plus, Black metallic with black leather
Located in Lancashire
Twinfan
Twinfan PCGB Member
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/26 08:18:59 (permalink)
Peter_Bull
Nick7602
Run out model for the 987.1:
https://www.pistonheads.com/news/general/porsche-cayman-s-sport-spotted/36326
CLIFFWILKINS
Re: Some Advice Please Guys & Gals, with this COVID19 and we cant drive 2020/03/26 08:34:19 (permalink)
I had a Cayman S Sport limited edition in Viper green which is a rare colour in uk.
Most are in Orange.
Current cars
Cayman R Peridot
Previous
GT3 Mk 2
GT3 Mk 1 S/Y Missed
996 4S
4 986 Boxsters
987 Boxster
3.2 Carrerra
944 &924
