Changing MPH to KM
991TurboS
I am currently in Ireland for 5 days and when I change the speedometer to read in Km/hour all is fine until I stop the car and take the key out. Upon restarting it automantically reverts to MPH
does anybody know to fix this?
my car is a 2017 911 Turbo S
regards
paul
Try saving memory to the key from the driver memory buttons on the door. ( like a seat setting). Put it in km, press memory on door, press key symbol, should beep. If it works, remember to do the reverse later for mph.
Alternatively you can tick a box on the PCM settings menu to ”Save settings on exit”.
Hi Guys
thanks for the tips
Keithn - I have have tried the first one - using the key memory - and it works
Clive - I will try your suggestion another time
regards
paul
