Hi guys
Does anyone have the part numbers for the usual suspects when there's 'zero' heat, I have lived with this for a long time but now want to sort it out once and for all. I have tried to read what info is available on the internet, alas Clarks Garage doesn't seem to be working. I know that there are plastic clips and solenoids which can fail and give you no heat which I'm hoping is the case here, I just need to know what/where these parts are before I start taking things apart, I'd like to start with the easy possibles first.
Some background info, '86' 951, the car is running fine, engine temp is fine, vacuum valve on the bulkhead works, heating pipes going into and out of the interior are both hot, the heating matrix was cleaned with pressurised water and showed no signs of a blockage, clean water went in and came out, no muck. Fans work, defroster works (no heat), A/C is fully working.
If anyone here has had a 'no heat' issue and fixed it, could you please give me the part numbers of what was required, I'm happy to just buy them, ready for when I take things apart, I believe that most cost very little, I just don't know what's what under the dash as I've never taken it apart...not yet at least...
Pete
