Zymoled and tucked up
- Thread starter ashley
Elliot Davies
***************************************************************ORIGINAL: ashley
Never mind that you should have seen my n*ts when I'd finished it was freezing
That cover looks really good zymol'd whats the car look like?
It doesn't appear to be 'plugged in' so I assume you don't have a battery conditioner (trickle charger).
With the alarm (and in my case tracker) you can expect the battery to run down quite quickly.
I had to ge Porsche Assist (RAC) out Saturday morning at 6.30am to start my beast and it had only been standing 4 weeks.
Helen Goff
No.1 Poster
Don't have one hence the RAC on saturday morning.
I'll enquire at AFN as I might get one fitted at the 1st service in Jan.
Do a search on the forums for battery conditioners (not the same as a trickle charger).
There have been several threads related to these.
(I use a Carcoon one - works great).
mikecolquhoun
timhum2002
65 degrees with the inference that the wax doesn't bond to the surface. Can any Zymol users confirm this and how do they cope with this guidance in our generally cool UK climate ?
Tim H
Dig out a pea-sized piece of wax and rub it between your hands, warming it thoroughly (melting actually) and spreading it nicely over palms & fingers. I then swiftly run my hands over a panel (only one at a time). This amount will easily do a panel the size of a door.
Use a microwipe to "take off" the Zymol after a couple of minutes, and an hour or so later buff the set finish gently with a 100% cotton towel to enhance the shine and really set the finish.
(This goes for all the Zymol waxes in a pot - even the Carbon or Creme ones. Forget the foam applicator, especially when it is cold.
Helen Goff
No.1 Poster
Helen Goff
No.1 Poster
Andrew Killington
Andrew
Martin
