944Scott
For the first time since owning the car and after removing the wastegate I finally have the car back together and I have boost, thankfully the shim did the trick. I ended up with 5 sheared bolts that needed drilling out and retapping only to find one was not tapped properly so another sheared bolt needed removing.
At the same time I removed two redundant alarms and a tracker, weight saving eh [
Oooh and the postie delivered the Linen vinyl material I ordered so I can crack on with the door pods at the weekend.
