Dan944t
Hi blade7,
yes the boring of my cylinders out and having dry liners fitted wasn't out of choice as I did tones of work a few years back and spent just over £7000 on all the parts I discribed above plus quite a few mods that I waited years and years to warren the cost!
what happened was that with all this extra power was absolutely stunning for about 2 months maybe then a head gasket symptom happened where I had loads of steam bursting out of the bonnet as I came off a motorway slip road. the water pipe that connects the top of the water pump to the metal water rail that goes around the side of the engine had burst open. After installing one temporarily from my non turbo, it kept bubling air and I could not bleed it out of the system. Having not long reb the top end myself I couldn't believe that it would have blown the gasket as everything had been changed. So it broke my heart and I couldn't bare to look at it for some time!
When I finally stopped feeling sorry for myself, I began to tear into the top end with a head gasket failier in mind. it's a long story but basically the head gasket was perfect as was everything I rebuilt as I had everything checked and I dug a bit deeper to find one of my cylinders had basically split right through hence wanting them removed and new wet liners installed, as I wanted to keep my engine numbers but obviously at a pricey cost which I just hope is worth it!
as long as it all works out in the end I am happy as throw money at a car that I cherish doesn't bother me it's just when things like this happen especially when you have spent 9 months on your back diung all the labour to find out you now have two choices look for a second hand engine which on any car is a risk, or pay through the nose and rebuild the one that's broke and because I can do it myself I chose to do this as I would rather it cost 5 times more than a second hand engine but keep my original as it's more sentimental to me and keeps it original if you understand where I'm coming from.
If if I could not of done this rebuild myself and had to pay a speacialist, I doubt I would have been able to afford it for at least another 10 years from now with the amount of labour charges it would entail! So I must thank my lucky stars that I'm capable.
Daniel
Daniel
