Wonky light covers
- Thread starter homesea
FistsOfHam
ORIGINAL: madrob6
One of mine rests about a cm too high where the other rests about a cm too low, I have no idea how to adjust them though.
Unless there is some other method, I believe sliding the mount for the operating shaft and motor fore or aft as appropriate will correct this. Of course it will also affect the "up" position so headlights may then need adjustment.
ORIGINAL: madrob6
1. Loosen all 6 bolts on both triangular plates either side of the headlamp pivot. 2.
2. Move the headlamp to where you want it to be
3. Tighten up the 6 bolts while supporting headlamp position
4. Swear profusely as one of the bolts moves the headlamp a little [
5. Repeat above ad nauseum until it's just right [
