Wiring Loom Recall
- Thread starter Nigel 911
Andy B Aces High
I am off to PC Tonbridge now to get my car booked in and discuss with the guys what they will be doing, will post a reply later today with some details.
Could be lots of cars in the Club that have not had the loom replaced and have a potential problem.
Andy B Aces High
Asked the question about risk of fire etc and they advise that it is very low risk and is replaced by Porsche as a precaution. Apparrently a small number of cars in the States had a problem so Porsche issued the recall.
If anyone out there is not sure then it is worth checking with their PC. The work is carried out free of charge.
timandlisa911
Tim[8D][8D]
There is a special part number for the replacement loom that was much cheaper than ordering the loom from the standard parts catalogue, somewhere in the range of £100. But if you need to foot the bill the labour charge will be the same.
Hacki
It took a full day to have the replacement done, so 8 hrs for fitting seems to be realistic. My car was at the OPC some years ago, maybe 10 or so?
In Germany it wasn´t just a factory recall, Porsche was forced to do it by the state, because the loom could cause engine troubles with potentially higher emissions, again IIRC.
Maybe another OPC could be worth a try.
Good luck!
T911UK
clyde
It's the fact that the manufacturing date of the loom is well inside the problem period, which according to the US stuff I've read is an instant replacement. That and obviously that it is showing signs of the issues.
I did come across the part number for the replacement loom a while back but I've no idea what I did with it, so another long web trawl for that.
clyde said:I should have said that I have ran it through the on-line checker and it came back clean. But that may be because the PC had erroneously updated the records after it was in ten odd years ago. They never instilled confidence in me at the time.
