My 993's 13 years old this month (haven't got it a present yet). As a teenager now, maybe it's going to get more expensive!?
Windscreen squeaks when going over bumps. There's no sign of rust around the screen, but quite a lot of moisture under the outside windscreen seal on both sides at the bottom of both pillars (where you might expect it to collect). No interior leaks (as far as I know!)
What do you think about squirting a little Waxoyl round the screen (under the seal on the outside). Will it damage the seal/bonding material? Might cure the squeak & prevent/hold off corrosion....?
This used to be a life saver under the rubber seals of older cars like Triumphs etc which I had a few years back.
Any comments before I start squirting?
