Windscreen Washers?
- Thread starter rjs993
Mine have frozen before now in cold weather.
Surprise, surprise.[8|]
colin appleton
Johnny C
The pump is in the passenger side (left) wing, behind the headlamp fitting. It's a bit of a pig to get out due to wires only being long enough to reach it (usually installed whilst the wing is off), hence I took mine in.
However it wasn't the pump, the pump was fine; the outlet from the tank had blocked up so the tank needed flushing.
Also worth a quick check, the hose with water in goes into the bonnet compartment. Mine didn't work once because it had been dislodged when I'd put something in there. Worth a check, just see if water comes out the bottom of the wing when it's stationary and you squirt it.
I use Porsche own and my friend did, and when he ran low he used normal screen wash. Never mix porsche's own screen wash and normal screen wash. It blocks the jets up! It turns into wax! We had to remove the jets and dismantle them to clean it out and flush the tank out too.
Don't know if this might be your problem?
Graham
