Hi All
It's that dreaded time of the year for the MOT and low and behold the Washers have decided to give up on my 86 924S.
Now I have started at the usual things - yes it has water in the resevoir, the fuse is in tact and all pipes are correctly connected.
THe car has, in the recent past had a new level on the steering column so I assume that this is OK. Also regarding this, if you pull the stalk towards yourself for long enough and hard enoungh the wipers will activate and do a double sweep of the screen. They wont however do it every time.
Can anyone offer some suggestions as to where I should go from here in trying to resolve this simple but, unfortunately MOT failing, problem.
Thanks to all in advance
Andy
Andy
