Will not idle: Increased resistance on primary coil
- Thread starter robwright
alwigley
robwright
alwigley
Will fire up and run for a few seconds before the idle drops really low and she dies - can sometimes hold the throttle open and hold her at 1750rpm + and she runs but a little rough. Sometimes I can then get her to idle, but on restart it happens all over again. If I turn on any additional electrics such as headlights, she dies completely......
Have followed the various checks on the injection system/electrics etc., checked all the grounds and the only thing I can come up with is that the resistance on the primary side of the coil is higher than the specification 0.4 to 0.6 ohms being 0.9ohms. So logic tells me that if the primary resistance is too high, then the coil output must be reduced and therefore it could be weak spark as a result.....
Has anyone experienced a similar issue ? Really want to get her running as I arrive at work with a big smile on my face when I can drive her !
Many thanks for your help - will post a picture when I get a chance to take one......
alwigley
alwigley
FistsOfHam
alwigley
JamesO
peanut
you've got that the wrong way round. if the fuel pressure regulator FPR fails to relieve pressure your fuel system will over-pressurize . It is the overpressure that shuts down the ECU and shuts down the fuel pump and injector pulsing. If you disconnect one injector and the car then starts it indicates too much fuel pressure. You can buy a simple cheap fuel pressure gauge off ebay for £10.00 just connect it to the fuel rail with a bit of garden hose and some jubilee clips.ORIGINAL: alwigley Have heard that the fuel pressure regulator on the end of the fuel rail can cause this sort of trouble, which can be proven by the simple expedient of disconnecting one of the injectors, so will have a shot at that this weekend.
alwigley
peanut
yes thats how it does work but it is only useful in an over-pressure situation. I thought you said you had an under-pressure situation. ie low fuel supply so the last thing you want to do is reduce the fuel supply. I haven't really followed this thread i'm afraid. I suspect there are several possible causes here and you need to do a thorough systematic check of everything using the Clarkes troubleshooting guides.ORIGINAL: alwigley Thanks chaps - very interesting to hear of a similar problem on the Prelude...... What is odd is that I am clearly getting a spark as I can get it to run with a heavy right foot, but lower down the range it just won't hold. Must admit that I thought the idea of disconnecting one injector odd, but apparantly it alters the level of signal sent back to the DME, and taking one off reduces the voltage return, kidding the DME into thinking the pressure is lower ? (Or something like that anyway - I know you can't trust everything you read on the net !)
sawood12
