Wideband o2 pick-up
- Thread starter sawood12
George Elliott
not very helpful I know [
but I have heard there is a system to measure O2 on the 4 individual cylinders so that must be on the manifold.
George
944T
sawood12
The o2 sensors i've seen on the market cannot stand the temps in the manifold which is why they need to be mounted further down the system. Though wouldn't it be fantastic to have a system that could run each individual cylinder in closed loop.
George Elliott
Admire your logical approach to optimising the engine performance.
George
944T
I heartily recommend the Wideband Commander, the software on the laptop is very easy to use and very easy to log your AFR agianst RPM once you hook up a wire to the coil. You can also configure it to give you an audible alarm if you go out of a user definable AFR range between a user definable RPM
sawood12
ORIGINAL: George Elliott
George
944T
A few years of reading on this forum you soon pick up a few things so can't take the credit for the methodical approach i'm afraid. There are plenty of real tuning guru's on this and other forums from whom you can learn from their experiences and mistakes. But from the odd tuning horror story i've read about that usually end up in major damage to the engine and a huge bill a couple of hundred quid on an AFR gauge becomes a very sensible investment.
Paul, I've not come across the wideband commander system you refer to. I did have my eye on the Innovate gauge system that does also have a laptop interface system and a 'record' mode but it does not specifically mention being able to log AFR against RPM. That sounds like a very useful feature. Does it mean that you can make a couple of runs without having to keep one eye on the AFR gauge, one eye on the rev counter and zero eyes on the road and allows you to review the trace afterwards and make the adjustments to your piggy back?
You can also export the data into a spreadsheet package and then produe a graph. This is my completed AFR graph after I fine tuned it with the Wideband Commander and Vitesse piggyback. It's also great geeky fun if you are feeling particularly nerdlike [
