Whos the lucky owner of the SE ?
- Thread starter earlybay
Copperman05
Edd
I seem to recall previous discussions about the SE concluded that it had the same chip as Promax sell. As Edd said, the 225bhp may or may not be realistic. Promax claim (or used to claim) 250bhp from their chip; when I quizzed Andy Sweetenham about this he said that they had genuinely seen 250bhp from an S2 on the rollers with their chip, but admitted that this was on the high end of what could be expected in most cases.
944 man
ORIGINAL: Copperman05
They are probably very similar, whether they produced 225bhp is another matter...
Edd
Yes, not a bloody chance! [
simkin911
I also turned down the opportunity to buy it for £3500 18 months ago and again last year for £5k when it appeared on Pistonheads in September after having had some money spent on by the next owner. Not a bad car by any means but it certainly isn't perfect and at the end of the day - whilst only 15 were "made" - the some total of the extras were nothing special by modern standards although the 968 M030 sized ARBs are quite desirable.
For starters, there is wear to the drivers seat bolster, the interior colour isn't great, the wheels aren't standard or that great IMHO, there's bubbling to sills and there are signs of paint over spray at the lower edges of the car where previous rust has been painted over. When viewed 18 months the rust was visible and although not terrible I was concerned about the rust I perhaps couldn't see (although I accept there may not be much more but I didn't see it on a ramp so elected to be cautious).
Just my opinion and comments of course....
AndrewS
ORIGINAL: zcacogp
I see what you mean about the lean, but suspect it may be due to (or emphasised by) the fact that the photo isn't taken head-on.
Hi All,
We had a customer car in 2004 that hat a cat bypass, ProMAX chip and K&N panel filter that recorded 250bhp and 219lb/ft torque at the Jamsport Dyno (Northampton) - the car did go very well, but after we switched to the Dyno at Weltmeister (before they disappeared), we realised that the Jamsport Dyno was possibly a little optimistic. However, the 944S2 with Cat (1990 model year onwards) did respond very well (generally) to that combination of upgrade parts (if engine compression was good and the overall engine was in good shape to begin with).
Only way to truly measure the effectiveness of an upgrade is a same day run on the same dyno (before & after). I would say that the ProMAX chip can be worth about 10bhp; additional benefits are improved throttle response and increases in torque at certain points in the RPM range.
Regards,
Andrew
earlybay
ORIGINAL: simkin911
I went to see this car in the flesh.
Makes me feel much better that indidnt buy it !
Ended up with a better condition car for fair bit less by the sound of it
