White dials
- Thread starter Guest
Stickers tend to have black "windows" for the warning lights whereas sets where the whole of all dials is white are replacements.
I bought a spare dash for an mph speedo once and it came with white sticker dials. They peeled off fine and the only mistake I made was in using nail varnish remover on a bit of adhesive that was left on the fuel gauge and it attacked the black. Remove the needles and peel carefully, and stick with warm soapy water and elbow grease if you get any adhesive remaining and you'll be fine.
If they are replacements then you need to find someone to swap with, but that isn't too bad as the replacements look OK and someone will want them.
If anyone thinks from my last statement I am implying the stickers do not look OK then you're absolutely right. They are bloody awful with those big black cut outs.
If you're deperate then buy a set of instruments from a breaker like Porschapart.![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
I know [:'(]!!! what kinda prat puts a nasty fake wood plastic stereo in a car with black interior [
When you do take them off do it very carefully - they just pull off but you do not want to bend the spindle. You get a needle puller with the sticker kit I think but getting one separate might be tricky. eBay?![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
Thats not unusual.ORIGINAL: Bigglesdan
my fuel gauge never shows any more than 3/4 full??
You need to unscrew the nine screws from the back of the dial cluster. This will remove the dials from the surround.
The needles will come off relatively easily. Probably the easiest way is with a small pair of curved pliers. Place the pliers so that they are under the middle of the needle and 'roll' pliers so they push up (lever) the needle. You can remove by fingers and use pressure to pull up, straight.
Panel wipe or lighter fluid should be fine to remove any glue residue if you use a small amount. The originals are plastic, so nail varnish remover will marr (sp?) Alcohol as oppose to acetone. Keep it for your nails Fen[
The needles work electromagnetically. If you place the needle roughly in the correct position on the spindle lightly but enough for it to turn, lightly move the needle round slightly and then allow it to fall back. It will return to it's 'first' position. You correct it by turning the needle one way or the other and check again. When happy, press down firmly in place.
Job done, walk away.
berg944
I also have a set of clocks with white dials (not stickers), I bought them off ebay for £90 but the wife did not like them (wants silver to match the car). If anybody wants them make me a reasonable offer! I can not guarantee them as I have not used them but the faces are the expensive type.
Mike
Oh, and I can't get my fuel gauge much above 3/4 full either.
Porsche used to do some for the 968 that were not like that, but they are probably discontinued and certainly would be expensive.![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
944turboS
Drivers_edge@hotmail.com
I don't know if they are still trading or not.
I think Prestige Parts had some full guage faces a while back too.
jez_anderson
