Whoah! I go out for the evening and find that this forum has become William Hill and my S2 is the nag of the day!
So, todays runners, in order:
- PAS Pump. 171,000 miles old (original, if the car's history is to be believed). Fluid was changed a couple of years ago tho', and topped up a month or so back. However it may be an odds-on favourite as the reason I topped it up was because the fluid level was low, which caused the pump to whine. That whine went away with more fluid (and this whine is different), but presents two questions; a) What happened to the fluid and b) did running the pump while low on fluid cause this whine? BUT, if this is the problem, then why does the whine only occur when the car is very cold and why does it go away after 5 minutes or so?
- Belts. Let's be clear, there are four belts in the belt-race; starting from the front of the field (engine), they are Power Steering, Alternator, Balance and Cam. B and C were all changed recently (12 months ago) and tension is fine. PS and A haven't been changed in 6 years, but look fine and the tension looks OK too. (Although PS may be a smidge tight - perhaps I should loosen it a little.)
- Belts (second consideration). Discussing this with a friend last night, he said that belts can be noisier in winter than in summer as the rubber hardens and behaves differently. As they run then the hysteresis of the rubber warms them up and they behave more normally and quieten down.
- Alternator charging. A firm favourite, and backed by Mas and our very own PCGB Technical Rep Mr B Gear (esq). Already been discussed at length and has strong form in previous races.
- Alternator bearing. A bit of an outside candidate, although from the strong Nuts stable and backed by Nick, and apparently has form too. Can alternator bearings be lubricated?
- Belt slip squeal. Never got off the starting line - sounds wrong, feels wrong and just doesn't fit in this race. Nice try, and I'm sure it will do well elsewhere, but not here.
Any early results? Drove the car for 40 minutes last night, and it whined for the first 5 of those (although didn't seem as bad as usual this time.) Left it parked for 2 1/2 hours, then another 40 minute drive home during which time it didn't whine at all.
So, gentlemen, place your bets NOW! (And thanks for all your input. Anyone know how difficult it is to rebuild a PAS pump?)
