Which oil to top up
- Thread starter Guest
adamtsobek
I have always used Mobil 1, full synthetic oil. I think a large proportion of 3.2 owners do also.
I understand that these old engines can run on non synthetics as well.
You could ring the dealer who serviced the car last, as they should have a record of what was used
Adam
Dave Wilkinson
If you don't know what's in there I'd be inclined to have the oil changed anyway - and then you will know. If it was done recently enough to not justify a change, ask them who changed it.
In my experience, most of the independents who work on these older cars (I'm including my 964 in that catagory) generally recommend the non-synthetics - like Castrol Magnatec 10W/40 - since the synthetic oils were certainly not commonplace when such engines were designed in the '60s. The most popular Mobil 1 (0W/30) is generally too thin for the older engines and will often promote leaks.
Dave
Add your car to your profile, makes answering your questions easier.
I run Mobil1 in my 930 only, it is not good for the actual engine.
Most people I have spoken to say the older cars are not so good with full synth oil.
ORIGINAL: oilman
If you just need to top up and you dont know what is in there then 10w-40 semi will be fine, all oils do mix without issue.
Cavalry to the rescue (of your wallet!)... [
