Wheels & Tyres - a definitive list
TonyRSR
Folks,​
As part of the 15 year celebration, in conjunction with our esteemed reg. sec. and others I'm putting together what should be a useful little document. As part of that, and because it's something that appears on this forum again and again I want to put together a list of wheels and tyres currently in use on the 964RS & derivitives.​
So if everybody could supply the following details (as per the example) t'would be great. It will be published - but no names will be mentioned!​
Wheel Type Size Offset Spacers Tyre Type Size ​
Front​
Cup 1 Mags 7.5x17 47 - Pirelli Rosso 205/50​
Rear​
Cup 1 Mags 9x17 55 18mm Pirelli Rosso 255/40​
Please, don't be shy let me know what your running.​
Mel, if you could nail this post to the top of the forum that would be useful.​
Thanks​
Tony​
For Track .......
Wheel Type Size Offset Spacers Tyre Type Size [FONT=verdana,geneva"]Front Cup 1 Mags 7.5x17 47 - Dunlop SSR 225/45 [FONT=verdana,geneva"][FONT=verdana,geneva"]Rear Cup 1 Mags 9x17 55 5mm Dunlop SSR 245/40[FONT=verdana,geneva"][FONT=verdana,geneva"] [FONT=verdana,geneva"][FONT=verdana,geneva"]For Street ........[FONT=verdana,geneva"][FONT=verdana,geneva"] Wheel Type Size Offset Spacers Tyre Type Size [FONT=verdana,geneva"]Front Cup 1 OE 7x17 55 - Marangoni Zeta Linea 215/45 [FONT=verdana,geneva"][FONT=verdana,geneva"]Rear Cup 1 OE 9x17 55 5mm Marangoni Zeta Linea 255/40[FONT=verdana,geneva"][FONT=verdana,geneva"]
For Dry Track .......
Wheel Type Size Offset S/p Tyre Type Size [FONT=verdana,geneva"]Front Cup1 Mg 7.5x17 47 - Dunlop DZ02G 215/45 H1/R1
[FONT=verdana,geneva"][FONT=verdana,geneva"]Rear Cup1 Mg 9x17 55 - Dunlop DZ02G 245/40 H1/R1
[FONT=verdana,geneva"][FONT=verdana,geneva"] [FONT=verdana,geneva"][FONT=verdana,geneva"]For Wet Track / Street ........[FONT=verdana,geneva"][FONT=verdana,geneva"]Wheel Type Size Offset S/p Tyre Type Size [FONT=verdana,geneva"]Front Cup2 OE 7x17 55 - Dunlop SSR 225/45 [FONT=verdana,geneva"][FONT=verdana,geneva"]Rear Cup2 OE 9x17 55 - Dunlop SSR 245/40[FONT=verdana,geneva"][FONT=verdana,geneva"]
Front Cup 1 Mags 7.5x17 47 - Bridgestone S-02 205/50
Rear Cup 1 Mags 9x17 55 18mm Bridgestone S-02 255/40
Hi Tony,
for Track
Front Cup 1 8x17 52mm Kumho Ecsta MX KU 15 225/45x17
Rear Cup 1 9,5x17 68mm 21mm Kumho Ecsta MX KU 15 255/40x17
for Road
same as above (second set) but with Marangoni Zeta Linea same tyre sizes as above
Wheels are the original Cup Race Wheels (also Mags) used on the 964, mine are from 1990
Regards,
Hacki
18" on mine
Front Porsche 3 piece Speedline Cups 8 x 18 - Pirelli P-Zero Rosso N4 224/40ZR18
Rear Porsche 3 piece Speedline Cups 10 x 18 - Pirelli P-Zero Rosso N4 265/35ZR18
For the Garage
Genuine Speedline cup splits
Fronts 8x18 with 225/40/18 black rubber bits
Rears 9.5x18 7mm spacer with 265/35/18 rubber bits
For the Driveway
std mags with Michelin pilot cup sports sticky things
Unfortunately I forgot to take the detail before I got them refurbed.
I know that the 10's off a Turbo II will fit but you'll need big spacers.
Wheel Type Size Offset Spacers Tyre Type Size [FONT=verdana,geneva"]Front Cup 1 Mags 7.5x17 std - Dunlop Super Sport 225/50 (35% worn)[FONT=verdana,geneva"][FONT=verdana,geneva"]Rear Cup 1 Mags 9x17 std 10mm Dunlop Super Sport 245/40 (80% worn)[FONT=verdana,geneva"][FONT=verdana,geneva"] [FONT=verdana,geneva"][FONT=verdana,geneva"]Could do with replacing the rears, are they still avail? - I quite like them overall.[FONT=verdana,geneva"][FONT=verdana,geneva"]George[FONT=verdana,geneva"][FONT=verdana,geneva"] [FONT=verdana,geneva"][FONT=verdana,geneva"]RSL RHD Cassis Std[FONT=verdana,geneva"]
ORIGINAL: Tony
Do you know the offsets for the speedlines guys?
Tony
For the 964 cup '92 speedlines they are;
front 8 x 18 Et = 52, part no 965.362.136.00
(same size as 965T & 993RS, diff centre to 993 version).
Rear, 9.5 x 18 Et = 47, part no 965.362.138.05
(Different rear ET to 965T & 993RS)
Sorry for lack of detail, I am better with 993 versions [;)]
Hi Tony,
I'm running standard Magnesium RS Cup 1s with Yokohama A008-P205/50ZR17 Front, 255/40ZR17 Rear.
cheers,
Richard
Hi Tony,
On the car at the moment are standard Magnesium RS Cup 1s with Yokohama A008-P205/50ZR17 Front, 255/40ZR17 Rear.
Have ordered a set of Cup 1 alloys with Toyo 888 205/50 ZR 17 Front and 255/40ZR 17 Rear to preserve the mags. (Des's advice)
Nick
Since all the wheels are off, high time I added to this!!
DRY SLICKS
[FONT=verdana,geneva"] Wheel Type Size Offset Spacers Tyre Type Size [FONT=verdana,geneva"][FONT=verdana,geneva"]Front Cup 1 MM? 7.5x17 52 - Dunlop SP 235/620 [FONT=verdana,geneva"][FONT=verdana,geneva"]Rear Cup 1 MM? 9x17 47 15mm Dunlop SP 265/630
WETS/ROAD
[FONT=verdana,geneva"] Wheel Type Size Offset Spacers Tyre Type Size [FONT=verdana,geneva"] [FONT=verdana,geneva"]Front Cup 1 OE 7 x17 55 - P-0 Corsa 225/45 [FONT=verdana,geneva"] [FONT=verdana,geneva"]Rear Cup 1 OE 9x17 55 15mm P-0 Corsa 255/40 [FONT=verdana,geneva"]
NB The Cup Cars HAVE to have spacers at the rear since the studs are so long.......
'92 Cup Car
Front Cup 1 OE 8x17 52 - Toyo R888 225/45
Rear Cup 1 OE 9.5x17 68 20mm Toyo R888 255/40
I've also got a set of standard 7+9x17ET55 Cup 1s - haven't tried putting them on this car yet. Will the rears be OK with the spacers (needed because of the long studs)?
They came with the car Tony, but clearance on the rears to wheel arch cigarette paper thin on slicks!!
ORIGINAL: Ian964
Should be OK, prob is if you have capped lightweight nuts (oooh, matron...[;)]) instead of open steel -the long studs will punch thru the tops without spacers.
