Wheel bolts
- Thread starter SHRS2000
Matt_at_Rushworth
Drop us a message at Rushworth Performance (01384 895491) , we've supplied replacement bolts for a range of Porsche'es now along side wheel spacers and suspension upgrades.
We stock the full range of ST suspension parts which supply some OEM style loose ball wheel bolts ideal for replacing Porsche OEM bolts.
Matt
Design911 have a range of replacement wheel bolts available, although I'm sure there are other suppliers like this:
https://www.frazerpart.com/acatalog/986_987_Boxster__Cayman___996_997_wheel_bolt.html
They are for sale and all are in excellent condition. Photo attached.
If you are interested, PM me for price and postage details.
Brian
Briggy
I also bought a socket from them that has a nylon cover inside and out, so won't scratch the wheels or the bolts. Their part number is SX03019.
Cheers,
Bryan
PM reply sent.
Brian
I am always very careful to make sure the locking key socket is properly engaged before applying the torque wrench. A short extension is preferable to a longer one on the torque wrench to keep the 19mm socket square with the locking key.
Brian
Anyome simply used plastic covers?
Briggy
If the new ones go rusty, it'll just paint the tops as it'll get expensive continuously replacing them! Mine old ones had also been tightened too many times dry, so was (perhaps overly) worried that they may be past their best.
Speaking of tightening dry, this https://www.ebay.co.uk/itm/222914290098 is the replacement for Optimol TA, recommended in my handbook.
Your handbook will also give you the correct tightening torque. I only know it's 130Nm for my 987.2 Cayman.
T911UK
Briggy said:Just replaced all mine at around £5.70 each from Design 911, original parts. Wish I'd known about Brian's black ones for sale, but never mind.
Cheers,
Bryan
That socket wont protect the bolts, it has nothing on the inside, it is meant to protect you wheels as it has a plastic outer sleeve.
AndrewCS
My wheel bolts are six years old, used all year round for the last three and are corrosion free / only slightly marked. I do not use any `lube` anywhere … just a wire brush on the threads and hub contact patches … with a wipe over using WD40 or electrical cleaner. Wheel to bolt contact areas are similarly cleaned / wiped.
Socket ... maybe this is ?
https://www.frazerpart.co...soft_socket.html#SID=9
I use a standard socket, taped on the outside to help mitigate any misjudgements …
Matt_at_Rushworth
sometimes even throw in the breaker bar!
Just bought £6 of plastic 19mm A/F bolt head covers to decorate the nuts. will post pics when done.
Complaints about unsightly rusting wheel bolts seem to occupy a lot of space on these forums and it's a shame that Porsche don't supply or offer plastic caps for all the bolts, the locking bolts included (VW have a neat solution). Titanium bolts of both types are a very expensive option.
Not too bad for much nicer product
