Whatsa happened to Indi9xx Jon???
- Thread starter Guest
I also forgot to mention that I spoke to SimonP today. He's too modest to post anything himself, but it turns out that immaculate red engine bay he posted a few days ago is now being filled with a 3L 16V engine, a full Garret BB turbo and a standalone ECU. It's going to blow my car out of the water [
morris944s2john
ORIGINAL: Diver944
-snipI also forgot to mention that I spoke to SimonP today. He's too modest to post anything himself, but it turns out that immaculate red engine bay he posted a few days ago is now being filled with a 3L 16V engine, a full Garret BB turbo and a standalone ECU. It's going to blow my car out of the water []
So thats effectively going to be a 944 S2 turbo????[
How much (roughly) would it cost to put something like that together??
sawood12
You'd end up with something really really special though, as Simon and Paul will when they finally get their steeds on the road!.
sawood12
Custom MAF, Chips, Injectors, Intercooler, Exhaust about £5k Suspension £2500-3000 Brakes £1200
Although saying all the foregoing I currently have about £20-25k in my car!
morris944s2john
Neil Haughey
Scary stuff. Give it a few years and we may all be saying that the way to go for project is S2 and not 951.
333pg333 isn't the guy on Rennlist a mate of yours from down under?
morris944s2john
Something I don't understand "its probably only breathing VE down at something like 80%. " Does this mean the S2 motor is basically a lazy engine. I allways felt it feels lazy like its not working too hard even at 6500rpm.
What does this mean and how would a non boosting turbo or supercharger give more power??
I've been reading about the guy on the 928 forum with nitrous. Has anyone done this to a 944 S2??
Neil Haughey
Basically the problem is that the S2 has an inlet manifold that works by pulse charging to maximise the breathing efficiency at a certain point. When I took a few measurements and compared against some equations in one of me books (Heinz Heisler - Advanced Engine Technology) it gave maximum efficiency at about 4K rpm. This is not surprising given that the peal torque is around that figure and it makes perfect sense to design an engine to give its best at the rpm level where it is going to spend a lot of time when driven hard.
The downside to using log type manifolds (or similar with only one throttle body and a plenum chamber) is that the breathing efficiency of the engine (VE = volumetric efficiency) gets worse in either direction away from the point where it works at its best. Again the book above has some typical curves which show a typical engines VE dropping down to 80%ish at high rpms.
In essence this is the reason why throttle body conversions work so well on many 4 pot NA engines, because it opens up the top end to make big power, often at the expense of low down and midrange torque.
Inlet manifolds like that in our S2's can be bettered by having 2 plenum chambers and then using electronically controlled flaps to switch from one to the other, hence also improving the breathing at the top end whilst keeping excellent mid range torque. A good example is Porsche's Varioram system like on the 993.
Neil Haughey
Forgot to add that a VE of 100% means the engine will fill its cylinders to an air pressure the same as the ambient air pressure. In other words the ideal boost gauge would be reading 0 psi boost. Note I said ideal because pressure measurements in any system where a large volume of air is moving at speed are subject to all kinds of complicated to sort out physics, that makes my head hurts.
morris944s2john
